'05 Screw Fx4 Sub/backseat
I have just purchased a 2005 FX4 Supercrew and would like to install a couple of subs behinde the rear seat. The problem is that the rear seats don't move forward and I don't know how much room is back there.
Has anyone done an install like this or have any tips?
If there is room is there a enclosure that is made to fit behind the seat?
I have seen the box that fits under the rear seat "is this the only way"?
I assume you're referring to an F150. There's zero space behind the rear seat. Notice how the seatbelts are attached to the seatback, rather than to the C-pillars as they were in the older 150 Screws... to get the structural stability to deal with those belts, the back has to be bolted to the rear wall.
This is also an issue for those of us using the 150 Screw as an emergency response vehicle, and a royal pain in the rear.
Maybe you could try doing what I did with my '03 supercrew. I first used a cardboard template to see what would fit, then designed a speaker box to fit under the rear seat. I don't know if the seat arrangment is the same on an 05, but it's worth investigating. Let me know if you need any additional information.
TonyC
http://www.geocities.com/tony_cricco/techie.html
TonyC
arcturner
11-03-2004 03:55 AM
