Problem: Headlights turn off spontaneously!
Old Jan 11, 2005 | 06:25 PM
goldfever's Avatar
goldfever
Cool Problem: Headlights turn off spontaneously!
I've got a 1994 Ranger 3.0L 4x4.
My headlights have started switching off completely at dangerous times on icy roads.
The problem usually happens when I switch from hi beam to low beam (ie, oncoming car)
The headlights will occasionally quit suddenly without me doing anything.
The problem is generaly uncommon and hard to reproduce, but has been becoming more frequent lately.
The running lights (orange) remain on when the lights quit.
The best way to restart the headlights seems to be to turn the main headlight switch on and off repeatedly.
My question is: what's at fault-- the main light switch, the multifunction switch, loose wires, a sticky relay? (Haynes says there are no relays, but I'm not satisfied with their wiring diagram)
Can anyone help me out?
Thanks!
Old Jan 11, 2005 | 07:10 PM
johnsjmc's Avatar
johnsjmc
Often there is a circuit breaker built into a headlight switch. They reset themselves when allowed to cool and will often trip at a lower than expected current when old. I don,t have a wiring diagram for a late truck to check to be sure . Have you added any higher wattage bulbs?
Old Jan 11, 2005 | 08:28 PM
Ken00's Avatar
Ken00
Welcome to FTE!!
I would suspect the MFS or it's connector, Ford has a lot of problems with them.
Old Jan 11, 2005 | 08:53 PM
goldfever's Avatar
goldfever
Hmmm.
No extra high wattage bulbs, that I know of.
Sounds like two votes for replacing the multi-function switch.
Cheers
Old Jan 11, 2005 | 09:52 PM
hreed's Avatar
hreed
Make that three votes for the MFS.
Old Jan 15, 2005 | 05:54 PM
captaincanuck's Avatar
captaincanuck
I have a similar problem but my lights flash and flicker. the other day my high beam light came on in the dash after i shut the car and headlights off, when i walked around to the front of my car i noticed the headlights flickering on and off, this with the truck off and headlights off, i cant figure it out, oh ya, i drive a 93 xlt
Old Jan 16, 2005 | 07:04 PM
rellik74's Avatar
rellik74
Ok I have a 94 ranger and i have had to change the headlight switch out twice in 180,000 miles. once about 80k and again at 120k
Old Jan 18, 2005 | 11:42 AM
petie's Avatar
petie
I had a similar problem with mine.....like you said.....check for loose wires on the headlight switch.
Old Jan 18, 2005 | 05:15 PM
b7200's Avatar
b7200
I have a 94 F150 that had the same problem. I put a a remote starter into it about 5 years ago. The starter at one point short-circuited, so I disconnected it and thought nothing of it. It turns out that when it shotred, it back-fed the parking light circuit and melted the headlight switch and the connector that attaches to it. Fortunately Ford has been using the same switch and connector for at last 10 years and I had a donor vehicle in the yard. Pull the headlight switch out and try to wiggle the metal contacts. Chances are one is loose and it won't hold continuity with a meter.
Old Jan 30, 2005 | 03:35 PM
ranger1996's Avatar
ranger1996
my lights go off periodically as well on my 1996......i have learned not to freak out when it happens and to jiggle the headlight switch........i should fix it though
Old Jan 31, 2005 | 05:58 AM
fords_forlife's Avatar
fords_forlife
I don't know if it will be the same for the newer model rangers but I had the same problem with the headlights in my '88 ranger. Thinking it was an electrical short somewhere I tore the wiring harness apart and started tracing wires. I eventually found that the both of the plastic connecters that plug into the headlight switch and the turn signal switch had started to melt causing loose wires. After talking to a guy at ford I find out that this is a common occurance and so I just replaced the clips and havent had a problem since.
FORDS_FORLIFE
mustangpt
Apr 22, 2015 09:59 PM
materthegreater
Aug 18, 2012 12:11 PM
StevePimer
Oct 31, 2009 07:47 PM
JockD
Apr 7, 2009 09:59 AM
opjgeorge
Electrical Systems/Wiring
Oct 29, 2002 01:48 AM
