headlights flicker on and off
Old Mar 27, 2017 | 08:52 PM
jackzisakis's Avatar
jackzisakis
1984 f250
my headlights have started to flicker on and off for about 20 seconds at a time. all other lights are fine. only head lights. im thinking its the switch. i want your thoughts before i go ahead and replace the switch
Old Mar 27, 2017 | 08:58 PM
Tedster9's Avatar
Tedster9
The switch has an internal circuit breaker. High resistance in the headlight wiring and harness, connections. If you clean up the circuit path the problem may go away.
If you want to see why, place a voltmeter probe on the negative battery terminal and the other on the negative terminal of the headlight bulb. Turn the headlights on. The voltage drop will be shown as a positive number. Anything more than a few tenths of a volt is excessive. This heats up the switch causing it to trip. Check the positive side too.
Old Mar 27, 2017 | 09:00 PM
rowdyredneck's Avatar
rowdyredneck
Does it do it on both high and low beam? It could be a bad connection at the dimmer switch. Floor mount dimmer switches are exposed to moisture and grime which can cause corrosion in the connections.
Old Mar 28, 2017 | 09:29 AM
cadunkle's Avatar
cadunkle
Switches are a common failure point. For a permanent fix install relays along with a new switch, it'll make your headlights appreciably brighter too.
69bluebeauty
13
Dec 14, 2012 01:05 PM
get_nick
Sep 13, 2010 05:36 PM
GarageFab
Feb 15, 2010 10:17 AM
grams72
Sep 23, 2009 08:48 PM
d0n_3d
1983 - 2012 Ranger & B-Series
Dec 1, 2003 12:19 AM
