vent window compatibility ?
Old Jan 9, 2015 | 10:39 PM
projectPONY's Avatar
projectPONY
Are the vent windows on a '67 interchangeable with my '68? *I know the inside handle is/looks different but aren't thse easily changed?
Old Jan 9, 2015 | 11:19 PM
crazed87bronco's Avatar
crazed87bronco
A 67 vent window will interchange with any other 68-72 pickup and also vise versa. The handle latch is different between the 2 but otherwise they are the same.
Old Jan 9, 2015 | 11:23 PM
projectPONY
Thanks for the reply.
Can I take the handles off my vent windows and install them on the '67 vents?
Old Jan 10, 2015 | 02:12 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by project PONY
Can I take the handles off my 1968 vent windows and install them on the 1967 vent windows?
No.
Originally Posted by crazed87bronco
A 67 vent window assembly (glass/frame/handle) will interchange with any other 68-72 pickup and also vice versa.
The vent glass and vent window weather strips are the same 1967/72 F100/750, but...
The 1967 F100/750 vent frames and handles are not the same as 1968/72 F100/750.
C7TZ-8121608-B Right & C7TZ-8121609-B Left .. Vent Window Frames / Obsolete
1967 F100/750.
C6OZ-6222916-A Right & C6OZ-6222917-A Left .. Vent Window Frame Handles / Obsolete
1967 F100/750 // 1966/67 Falcon/Fairlane/Comet/Bronco / 1967 Mustang/Cougar.
C8TZ-8121608-A Right & C8TZ-8121609-A Left .. Vent Window Frames / Obsolete
1968/72 F100/750.
C8OZ-5422916-B Right & C8OZ-5422917-B Left .. Vent Window Frame Handles / Obsolete
1968/72 F100/750 // 1968 Mustang/Cougar / 1968/69 Falcon/Fairlane/Comet 4 Door Sedans / 1968/70 Falcon Station Wagons / 1968/71 Fairlane/Torino Station Wagons / 1968/77 Bronco.
They look the same, but looks can be deceiving.
1967 F100/750's use dozens of unique parts that are not the same as 1968/72 F100/750's.
For example ~ 1967: You push the inside handles forward to lock the doors. 1968/72's have door lock *****.
1967 only: Door shells, door lock remote controls, window regulators/handles, inside door handles, door latches, vent frames/handles, armrests, door lock cylinder link rods.
1967/72 same: Door & vent glass, weather strips, division bars, door lock cylinders, upper & lower door hinges, outside door handles.
Old Jan 10, 2015 | 06:48 AM
f100today's Avatar
f100today
A detailed explanation starts at post #9
https://www.ford-trucks.com/forums/1...g-windows.html
Old Jan 10, 2015 | 10:06 AM
crazed87bronco
^Very good thread link on the topic
Old Jan 10, 2015 | 01:45 PM
projectPONY
Ok guys, thanks.
brbuchanan
May 30, 2015 07:35 PM
SIXTFOR
May 28, 2014 11:05 AM
PA74F250
16
Nov 8, 2013 12:38 PM
floridaboy352.mh
Oct 16, 2013 03:29 PM
Parrt
Apr 18, 2013 02:40 PM
