Sponsored by: Real Truck
2004 Super duty running rough. Need help!
Old Jan 9, 2015 | 12:31 PM
J_Bowers04's Avatar
J_Bowers04
I have a 2004 SD with 5.4 that is running pretty rough both at idle and driving. Truck shakes a lot at lower rpms. I have a scan tool and had a misfire on cylinder 4 so I replaced the coil and the plug. Also replaced the idle air control valve. Plan on replacing O2 B1 S2. (One of my codes) even after replacing the coil and plug I'm still getting misfire detected from cylinder 4??? Other codes I had were misfire detected on he first 1000 revolutions. That hasn't come back though.
Old Jan 9, 2015 | 01:06 PM
CJ2003F250SD's Avatar
CJ2003F250SD
If its only cylinder #4 I would possibly suspect the injector. If the code resets quickly after clearing it then perhaps swap injectors and see if the misfire follows. They are about $120 i think to replace each.
Old Jan 9, 2015 | 02:26 PM
J_Bowers04's Avatar
J_Bowers04
Thank you! I'll have to check that out when I get home.
Hocus Focus
Dec 9, 2013 11:23 PM
southern_thunder
2004 - 2008 F150
Oct 10, 2013 08:52 PM
willtim1234
Modular V10 (6.8l)
Aug 18, 2013 11:03 AM
bill33
Jul 15, 2011 01:14 AM
MDSuperDuty
Feb 15, 2011 07:26 PM
