Coil Pack
Old Jul 14, 2011 | 05:02 PM
bill33's Avatar
bill33
Coil Pack
Hope ya'll can help. Coil pack on number one cylinder has gone bad. How do I determine which is number one?
How difficult is this thing to change out?
Is a 2005 Exp. Thanks for any advice.
Old Jul 14, 2011 | 05:04 PM
alloro's Avatar
alloro
#1 is the front one on the passenger side. They are numbered 1-4 front to back on the passenger side, and 5-8 front to back on the driver's side.
You're lucky it's #1, that one is fairly easy to get to. Now if it was #4 or #8 (the back two), then you'd be in for a real treat.
Old Jul 14, 2011 | 05:22 PM
bill33's Avatar
bill33
Thanks for the quick reply alloro. I got it replaced. The engine light is off and it idles well in park and neutral, but still a little rough in gear. Any ideas? Will it just have to work itself out.
One of the error codes said it was running rich, so thinking that might need to run for a bit.
Old Jul 14, 2011 | 10:30 PM
R&T Babich's Avatar
R&T Babich
Originally Posted by bill33
... but still a little rough in gear. Any ideas? ...
You may have another misfiring plug, it just hasn't gotten frequent enough for a code to be set. Our 2003 started the same way running a little rough under load, then getting to where there was an occasional misfire at idle. No codes. Finally got a code and then another before I could get to fixing the first one. The #6 & #7 springs in the boots were rusty from water dripping on them.
Could be a sticking fuel injector, but I haven't had that problem with ours.
Old Jul 15, 2011 | 01:14 AM
alloro's Avatar
alloro
The ECM learns how to control the engine based on various sensors. Now that you've corrected the misfire in #1 those stored parameters are theoretically no longer accurate. You could try disconnecting the battery for 10 minutes to wipe the ECM memory. Then after driving about 20 miles it will have relearned how to control the engine again. If that doesn't correct the problem you might have to clean the IAC valve as shown in this thread: https://www.ford-trucks.com/forums/9...4l-triton.html
mniewald
Jul 26, 2011 04:46 PM
tpw35
2004 - 2008 F150
Jul 24, 2008 11:00 PM
exppai04
Oct 26, 2007 08:40 PM
wdb1971
1997 - 2003 F150
May 24, 2006 07:39 PM
keithexpedition
Nov 6, 2004 12:38 PM
