Engine Tear down
Old Jan 11, 2015 | 07:26 AM
F-250 restorer's Avatar
F-250 restorer
Originally Posted by fordboy300
Well I was at swap meet/car show looking for a Holley 465 and I saw a couple manifolds this guy had they were all clean and my eye crossed when I saw he had a c-series it was a sign I wasn't gonna leave without it. The guy wanted 260 my girlfriend sister in law and I talked him down and he settled for 200 dollars. About a month later I found a Holley 465 off a tbird on eBay. Rebuilt it now I can't wait to install every thing.
Now I remember. Good for you. AbandonedBronce has both DP and C. Iirc they are hard to tell apart. For adjusting the carb the C can't be beat. I have DP and a Cliff. v.cover, and adjusting the mix screws with a flex tool even is impossible.
Steamed the water off your hood. If you don't get carb issues, hard hot starts, then you're good. (I still like the idea of the 2" holes in hood and a scoop to help vent the heat, but, I imagine, I'll go the efi route.) I do believe a cool air intake would increase mpg?
Old Jan 11, 2015 | 10:18 AM
dylansf23's Avatar
dylansf23
I'd love to do either a big wide scoop. Like the outer hood lines, or a shaker scoop like off an old fastback...but that patina I have and daily driving her would be ended at that point.
Old Jan 12, 2015 | 10:01 PM
dylansf23's Avatar
dylansf23
Got my exhaust ran! Photobucket isn't working right and saving my stuff right now...
it goes over my crossmember, into the muffler. And then a down turn.
Really actually kind of quiet, however it does have a rather deep tone to, almost a drone at idle. However there is no drone and it really roars when revved! Only cost 200$ also.
Old Jan 12, 2015 | 10:32 PM
F-250 restorer
Very nice. I look forward to seeing the photos. Please supply the name of the muffler and diameter of pipe, tips, etc., you may have used. I'm getting close and need the info.
... if I run duals I believe I'll have to put one pipe above trans cross member and one below. There's simply not room for both up there. Because the down pipes are on top of each other coming off the manifold, I may go dual 2.25" to muffler at rear axle, and single 2.5 out the back. I'm still planning.
Old Jan 15, 2015 | 10:31 AM
fordboy300's Avatar
fordboy300
After long searching I knew I still had this photo some where! I don't know where I got it from but before I had even thought of doing my rebuild I saw this photo and I wanted my exhaust like this. I wonder what it sounded like.
Old Jan 18, 2015 | 08:21 PM
F-250 restorer
I love that photo. It just got to my archives. Thx. The only iffy things I see are this: Where the one pipe crosses the collector flange of the other, and where it tucks under the c.member, I would want about 1" clearance to avoid rattles. Secondly, I'd have the bulb/ball type connection, not the old flange/flange that can leak and drive ya as crazy as a rattle. If using the flange/flange type collector, I'd recommend one of the locking header bolt systems like Grade 8. Believe that's the name.
If the phenolic spacer solves my heat sink problem I'm keeping my beloved header.
BTW. Today, while measuring the I.D. of my EFI's, and coming up with 1 11/16", I couldn't help but remember reading several times on the forum where members stated that the efi's flowed nearly as much as headers. I don't know what universe they got that info from, but the Hedman header has collectors of 3 1/2" o.d., which is about DOUBLE that of the efi's! And it flows nearly the same? Me thinks not.
It would be interesting if someone could come up with a way to combine three efi's, as done with the oem intakes, and create a 3 pipe system, maybe dumping into a single 3" tube.
Old Jan 18, 2015 | 09:58 PM
fordboy300's Avatar
fordboy300
That's small compared to my down pipe. I have 2 1/4 from the outlet of the manifolds to my MagnaFlow muffler and then a single 2 1/2 pipw running right before the rear axle and then dumped. I just showed the shop a picture of a down pipe and they tried mocking that one I told them all I want is to clear that starter please!
Old Jan 19, 2015 | 11:23 AM
F-250 restorer
That sounds like a real nice system you have. How does it sound? Are you happy with it?
Old Jan 19, 2015 | 12:11 PM
fordboy300's Avatar
fordboy300
Yes I am! It's sounds awesome. I love it. Ive had flowmaster and dynomax mufflers before I think magnaflow is by far the best choice I have made its quiet when cruising and then when you get on it, it has a nice rap to it.
Old Jan 20, 2015 | 10:03 PM
trozei's Avatar
trozei
I would imagine that the DP intake manifold requiring the sideways installation of your carburetor doesn't aid much in this situation. Another reason that I prefer the C. IMO, the DP doesn't offer any gain.
Old Jan 30, 2015 | 09:02 PM
TheDudeAbides's Avatar
TheDudeAbides
found this while searching around for exhaust ideas. its for a 200 in this fella's falcon, but its clean, simple and works. this guy's car sounds mean lol.
Falcon Fanatic
catto95
Jul 12, 2019 12:23 PM
littlehorse
Dec 6, 2018 10:25 PM
nolan62
Aug 14, 2016 04:50 PM
bullnose1985
17
Aug 2, 2015 07:28 PM
ibuzzard
Jul 19, 2008 03:16 PM
