300 c.i. Questions
Old Jul 16, 2008 | 07:54 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
300 c.i. Questions
First,does a 300 bolt up directly to an AOD transmission?Which years were carbureated,and which were fuel injected.Lastly,I remember Col. Flashman had a preference for a particular year,for which reason I can't remember.Anyone remember the years/reasons?How about you,Col.?Could you provide me a copy of the article you used to spec your build?I am considering doing this swap in my '59 F250.Thanks,Steve
Old Jul 16, 2008 | 11:16 PM
Iman901's Avatar
Iman901
The 300 will bolt up to an AOD, anything before 1987 was carbed, after '87 was fuel injected. the EFI engines had a different cylinder head design which was more efficient and had a higher compression ratio, they also used dual exhaust manifolds where the carbed motors had one.
Old Jul 17, 2008 | 07:16 AM
Motorhead351's Avatar
Motorhead351
As far as blocks go, I dont think there is a preferance. Unless you want a mechanical pump for a carb, then the earlier engines had that provision already cut, although, its not complicated to make the efi block compatible to a carb fuel pump, as the bolt holes are already there, just drill out, hack cut a spot for the fuel pump arm to pass through with enough clearance for movement and your good to go.
All engines, 240/300 carb or efi, used the same camshaft, from the beginning to the end.
Its safe to say all cylinder heads flow about the same, stock. Main difference is the carb engines used studs and the efi used pedastel mount. The efi 300 head and 240 have smaller chambers as mentioned. The carb 300 head has a open chamber design, this allows for easier flow potential. If your looking for a stock engine, the efi 300 would be great for a daily driver, the chamber offers a swirl to the incoming air/fuel which allows less timing to be used. However, from a performance perspective, it sux, as the intake valve is shrouded horribly in stock trim, it would take some massaging to make it flow, as well as a carbd 300 head. The efi heads are also prone to crack, another downside.
Carb engines used a single outlet exh manifold, efi used dual 3 to 1 manifolds, this is a definite improvement over the single outlet exh manifold...however....you can get long tube headers for a little over a hundred (hedman) and they would be more ideal for not alot more money.
Offenhauser and clifford performance is your only source for aftermarket intakes.
Any header company is likely to have a header for your truck.
Any camshaft company can offer a camshaft. They all list their camshafts with the ideal operating range, its a no brainer, pick the one that falls into your driving habits. Believe it or not, one offers a hydraullic roller cam, not cheap. A couple offer mechanical roller camshafts.
crane is the only source I can think of for roller rockers.
The stock valves are something like 1.75 intake and 1.56 exhaust. The exhaust valve is real close to the standard 1.6 that most people use when upgrading the exh valves, so Id stick with stock to save some cash, unless it needs to be opened further. 1.94 is a good choice for the intake side on the 240 or 300 carb head....you could put the larger valve in the efi head but youd spend a couple days grinding the hell out of the combustion chamber...not worth it IMO, major drawback to this head.
The only other thing you should look out for, is some 300's had forged cranks, most had cast. There is no real way to tell which engine had which, you have to put the crank in your hand and look at key differences to distinquish which is which, if I remember right, an easy way to tell, the cast had casting lines the steel do not...other than that, some folks find a spot and take a drill bit to it, the cast will crumble, the steel will draw up material into something of a curl like a pigs tail. You need to search to verify this but I believe it to be correct. With all that said, frenchtown flyer drag races these old engines and hes said time and time again that the cast is extremely strong and as far as street engines go, it would work fine. I think some have even gone as far as saying they ware good to 400~500hp.
As far as transmissons go, the inline engine and the SBF share the same pattern, if it goes behind a small block, it will go behind your engine.
efi engines used phenolic gearsets (dense plastic of sorts), so should you choose to use an efi block, pick up a gearset intended for a carb engine pre 80 to be safe, they'll be metal. Some gearsets are fine and some course teeth. Fine is weaker than the course, so if given the option, choose course. If youd like to degree your camshaft, then opt for an adjustable timing gearset (cloyes).
Good luck
Old Jul 19, 2008 | 03:16 PM
ibuzzard's Avatar
ibuzzard
Thanks for the info/responses,sorry it took so long for me to reply.I had also posted this in the 48-60 Forum.I will most likely do this swap when my Y Block poops out,though it runs beautifully now.Since my '59 is my only form of transportation,I need to cut my fuel costs,without losing performance.I commute 60-70 miles per day,in a 49 year old truckCol.Flashman's build,as listed in his gallery is what I want to come close to duplicating.If I am correct,he claims obout 22-25 mpg-much better than my current 15/16.I've already changed the gears in the Dana 60 from 4.56 to 3.54's.The combo of 300 c.i. with an AOD,which has the non-electronic "controls"that I want,should make it do-able.Thanks,Steve.
Col Flashman
Sep 15, 2013 11:59 PM
ibuzzard
Jul 17, 2008 02:42 AM
Col Flashman
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Jan 13, 2005 04:26 PM
Col Flashman
17
Jan 11, 2005 10:38 AM
Col Flashman
Sep 2, 2004 06:31 PM
