Speedo not working
Old Jan 6, 2015 | 05:38 PM
badger2196's Avatar
badger2196
Speedo not working
My speedo has stopped working (it started failing by going up to a certain speed and then stopping, but gradually got the point where it doesn't work at all). My cruise control is also non-functional (I assume that's because it needs to know what speed I am doing!). The ABS light is also on (related?).
I have seen threads on this related to automatic tranny trucks, but mine is a 6 speed manual and I have no idea where to start. Any ideas guys?
Old Jan 6, 2015 | 06:58 PM
jasonc76's Avatar
jasonc76
Speedo is determined from the vehicle speed sensor vss , which is on the rear differential. It's part of the abs system so ya it makes sense that the lights on. I'm not sure how to properly diagnose the problem without just throwing a new vss at it. I know with AE you have to go into abs to recalibrate the speedo for bigger wheels. Maybe there is a functional test in there you can run?
Old Jan 6, 2015 | 10:40 PM
snakedoc's Avatar
snakedoc
It's the rear speed sensor as that is where the truck reads the speed from.
Old Jan 7, 2015 | 01:50 AM
jgilrfr's Avatar
jgilrfr
what they said speedo senseor on rear akle just make sure you clean around it before removing or the crap will fall into the housing
Old Jan 7, 2015 | 10:14 AM
badger2196's Avatar
badger2196
Thanks for the replies. VSS investigation is set for the weekend (and sounds a lot easier than fishing around with a speedo cable!).
Old Jan 7, 2015 | 11:01 AM
jgilrfr's Avatar
jgilrfr
its very easy should be a couple minutes and done
Old Jan 7, 2015 | 06:11 PM
snakedoc's Avatar
snakedoc
There is no speed cable all electronic
vortec 1
Jul 7, 2013 09:04 PM
fredo181
Electrical Systems/Wiring
Nov 16, 2009 09:45 PM
oldblue31
Apr 17, 2006 05:58 PM
JICASE
Jan 6, 2005 08:54 PM
Cuda444
Oct 25, 2004 07:28 PM
