Axle Code
Old Jan 6, 2015 | 03:02 PM
Diesel_Brad's Avatar
Diesel_Brad
Axle Code
I am putting outer axle bearings(wheel bearings) in my 04 Ranger. Axle code R7
It has a 8.8 diff cover 10" x2.5" rear brakes, 2.25OD x 1.375 ID bearing. But for
some reason the 6408 wheel bearing I got from Advance are WAY too big.
The Torrington bearing that came out DB67309 crosses over to a 5707 which they show as a 7.5"
Old Jan 6, 2015 | 03:10 PM
smalltrucker's Avatar
smalltrucker
The 7.5 and 8.8 are the same except for the center section, take the same bearings ect.
Dave
Old Jan 6, 2015 | 06:02 PM
Diesel_Brad
Not according to advance and autozone
7.5 takes 5707
8.8 takes 6408
Jeffs bronco graveyard also shows different part numbers as well
Old Jan 6, 2015 | 07:19 PM
smalltrucker
The bearings and axle shafts are the same for both the 7,5 and 8.8 28 spline rear ends, It's the 31 spline 8.8 that takes the larger bearing.
Dave
Old Jan 7, 2015 | 08:14 AM
Diesel_Brad
ok. SO I have 28 spline axles?
Because none of those spots said anything about different spines
Old Jan 7, 2015 | 02:56 PM
exranger06's Avatar
exranger06
Most Rangers came with either the 7.5 or 28-spline 8.8, which use the same bearings. Only a few, namely the FX4 models, came with the 31 spline 8.8. The parts store computer SHOULD list all three options, but it's possible and likely the computer erroneously omitted one or more of those options.
In the future, if you're looking for rear bearings or seals, just lie to the parts guy and tell him you have a 7.5.
Old Jan 7, 2015 | 05:06 PM
Diesel_Brad
LOL. @ 180K I hope I don't have to touch this rear again
Johnnyboy1979
1997 - 2003 F150
Sep 2, 2010 10:31 PM
benshere
1978 - 1996 Big Bronco
Mar 7, 2008 08:10 AM
thorman
Offroad & 4x4
Apr 13, 2005 08:28 AM
dunebuggys
May 7, 2000 05:05 PM
