Trailer problem
Old Jul 20, 2003 | 08:09 PM
belly boat's Avatar
belly boat
Question Trailer problem
I have a 95 F-150 and my lights and everything was working great. Now my driver side rear signal and break light dont work anymore. The plug in the rear is a 7 pin and I have found the problem to be in the truck and not the trailer. I am prety sure that it is the yellow wire and I have traced it form the rear to under the dash and there is no break in it. I am not sure if it is hot or not or what it is supposed to be. HELP.
Old Jul 20, 2003 | 09:38 PM
steve83's Avatar
steve83
Trailer problem
It should go hot when you hit the brakes, just like the other side. Have you changed the bulb?
Old Jul 20, 2003 | 09:51 PM
belly boat's Avatar
belly boat
Trailer problem
yes deffinitly not the bulb. No power at the plug on the truck.
Old Jul 21, 2003 | 11:56 AM
belly boat's Avatar
belly boat
Trailer problem
Never mind fixed it.
Old Jul 25, 2003 | 12:14 PM
steve83's Avatar
steve83
Trailer problem
So what was it?
Old Jul 26, 2003 | 10:28 PM
HomerWinzlow's Avatar
HomerWinzlow
Trailer problem
I see this commonly when a bad 4 way flasher switch is in the on position. It will disable the brakelights and one or both turnsignals. You can usually get it back by putting the 4 way flasher back to the off position, but the proper fix is to replace the multifunction switch.
Ryan Skipper
All Things Towing
Nov 13, 2021 06:12 AM
Codydrake42
Sep 15, 2016 12:22 PM
tonylop33
Electrical Systems/Wiring
Mar 5, 2014 03:03 PM
Synthia
Sep 18, 2013 12:24 PM
celticrebel
1978 - 1996 Big Bronco
Mar 26, 2004 11:37 AM
