No trailer breaks???
Old May 8, 2016 | 08:38 PM
Ryan Skipper's Avatar
Ryan Skipper
Just bought a 2000 f350 as a second work truck and need to tow my new dump trailer. Installed new break controller and 7 pin adapter on back of the truck (old ones were gross and corroded). Now All the lights work but breaks won't engage. Breaks didn't work with old controller and 7 pin. I know it's not anything to do with trailer, works just fine with my other truck. Thoughts???
Old May 9, 2016 | 04:59 AM
senix's Avatar
senix
check fuses both under the hood and in the cab.
Since you have ruled out the trailer as working you will have to start at the fuse block and follow the wires probably.
Old May 9, 2016 | 05:24 AM
Chuck's First Ford's Avatar
Chuck's First Ford
and double check the Ground connections.. both truck and trailer...
do NOT rely on a ground coming from/thru the hitch.
Old May 9, 2016 | 07:29 AM
RV_Tech's Avatar
RV_Tech
Seven pin on truck
Old May 10, 2016 | 11:18 AM
Freightrain's Avatar
Freightrain
Does brake controller light up? Does it show any activation? If so then it is downstream from that. If it doesn't work then you need to check power.
Old Nov 12, 2021 | 08:11 PM
Chris3's Avatar
Chris3
sorry wrong thread
Old Nov 13, 2021 | 06:12 AM
Trawlerphil's Avatar
Trawlerphil
I don't know about the older trucks, but I found 4 frame grounds on my 2018 F-150. If something electrical doesn't work, most of the time it is a bad ground.
Casperman87
Mar 14, 2019 05:27 AM
DavidCarr
All Things Towing
Mar 23, 2015 07:56 PM
FloridaStroker
All Things Towing
19
Jun 15, 2013 07:22 AM
MKRemi
6.7L Power Stroke Diesel
22
Apr 12, 2012 07:48 PM
fastcarz3
Apr 22, 2006 07:26 AM
