Sponsored by: Real Truck
Remote Tailgate Lock DIY
Old Jan 4, 2015 | 07:00 PM
lotecredneck's Avatar
lotecredneck
I have a Bakflip G2 on my truck and like to be able to lock the cargo area so you can carry items without them being seen or stolen. I did this on my '10 F-150 and thought I would do the same on my '14 Super Duty. This is a very easy mod that can be done in an hour or so.
I ordered a couple of cheap universal door lock actuators from eBay for $8.00 You only need one, but I figured I would keep an extra around in case of a failure.
I started by removing the fasteners on the tailgate cover and then just spun it around the assist handle to gain access to the locking mechanism.
Once you can see the lock you can then figure out where to drill the one hole that is used to mount the actuator. Once you mount it then you will need to bend the round rod that looks like a "spoke" to attach to the lock and cut off any excess length. This bends easily with a couple of pair of pliers.
This picture shows the black rectangular locking mechanism. You can also see the clamp that the rod attaches to.
This photo shows the gold colored clamp and the rod as well as the brass colored screw that attaches the actuator to the tailgate. You can see how I bent the rod in several places in order to connect the rod to the actuator and locking mechanism. It doesn't have to be very precise as the end of the actuator swivels and it simply has to move one about a 3/4".
I then ran the wires out of the bottom of the tailgate and attached it to the other wiring for the camera. I put it in a 1/4" split loom and ran this along the frame rail to the passenger side rear door sill area. (You may want to consider putting a disconnect plug at this location in case you need to remove your tailgate.) I then removed the step plate and drilled a hole and ran the wire into that area. You will then need to run the wire around the door pillar and into the passenger front door sill area. I came in through the rear area because there is a lot more room there to drill and run the wire into the cab.
There are only two wires coming from the actuator. You will look for and use the Violet with Gray Stripe and the Gray with Tan Stripe for the actuator control. They are located in the bundle under the step plate in the front passenger door channel forward of the "Y" in the bundle. These wires will lock with one push and unlock with two pushes of the remote keyfob button just like the doors. It will unlock immediately with the door control switch. You have a 50-50 shot of getting it right! If it's backwards, just reverse the connection before finalizing your connection. Total price is about $10-$15!
Cheers,
~Tony
Old Jan 4, 2015 | 07:48 PM
slpcth's Avatar
slpcth
Nice job and pics. I wish I would have seen a month ago before I installed a Pop & Lock kit. Thanks for sharing a good idea.
Old Jan 5, 2015 | 10:47 AM
Larry Straight's Avatar
Larry Straight
I'm going to do that to my truck!
Why is it that a $15,000 Escort has remote truck release but a $55,000 Super Duty does not????
Old Mar 28, 2015 | 06:17 PM
Larry Straight
I installed a PopLock in my tailgate and love it!
I could of made my own bracket, but I spent the same amount of time doing some consulting work and earned more money than the PopLock cost me.
It is a relief knowing my tailgate is locked. I am more concerned about someone stealing my tailgate than I am about what is in the bed.
Old Apr 1, 2015 | 01:58 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Nice write up. Reps sent.
White gold
Jul 31, 2019 10:37 AM
welbo97
Jan 18, 2013 10:51 PM
my996duc1
6.7L Power Stroke Diesel
28
May 20, 2012 02:19 PM
cecilt
Jan 16, 2011 01:22 PM
390XR7
2004 - 2008 F150
Dec 18, 2005 06:47 PM
