Add or Delete?
Old Jan 3, 2015 | 09:23 PM
Icthus in AK's Avatar
Icthus in AK
Add or Delete?
2013 6.7L with 18k miles. What's the smart thing to do if my goal is to keep this truck 20 years or 350k miles: buy Flood Ford's ESP w/ Diesel Care for about $5k or just do a total emissions delete when it's out of warranty? What are the pros/cons to each? I'm military--am I hosed if I move to California if j do a delete it am I covered if I'm an Alaska resident and the truck is tagged in AK?
Appreciate your thoughts...
Old Jan 3, 2015 | 09:44 PM
System's Avatar
System
Prolocutor
Wow, I can't even be sure I'll still be alive in 20 years, never mind want the same vehicle that long! A lofty goal for sure and one that can't be assured success through either option you posted. If you are still on the 6.7 section of the board in 20 years you'll be a huge exception and not the rule. I'm sure over 99% of 20 year old truck owners aren't the original buyer...
Old Jan 3, 2015 | 09:56 PM
BlackBeest's Avatar
BlackBeest
Heh, in your shoes, I'd delete it once it's passed the 5yr/ 100k powertrain warranty. For a couple reasons:
You've got a '13, so far they're a little less "temperamental" than the 11/12s, afaik...
Also, it doesn't appear you "need" to make this decision anytime soon, you're averaging 9k/yr mileage. You'll run out of 5yrs in 2018 well before you get that 100k outta the way.
Lastly, if the truck and you are still AK registered residents, you shouldn't fall under Ca inspection requirements, but don't quote me on that....
Old Jan 3, 2015 | 10:00 PM
Icthus in AK
Thanks, Beest--your input is helpful.
Old Jan 3, 2015 | 10:44 PM
Chad149's Avatar
Chad149
And keep in mind the esp diesel warranty only adds two years onto the five. It's seven years from the original in service date.
Old Jan 3, 2015 | 11:12 PM
Icthus in AK
Doh! That's true... Thanks.
Old Jan 4, 2015 | 02:00 AM
WK15's Avatar
WK15
Here in alaska too.
If you keep alaksa tags you will be good to do full delete. I've deleted all my trucks while in the military. I also have kept alaska tags on all my trucks for 20 plus years. Never a problem out of state. If you do a full delete just keep all the parts to return if you ever sell the truck. I also have the ESP no issues so far from the dealership.
Old Jan 4, 2015 | 04:00 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
How about just maintain it well?
Old Jan 4, 2015 | 07:32 AM
ruschejj's Avatar
ruschejj
Regarding the AK residency/CA vehicle operation.
I wouldn't assume that you are protected from ca vehicle laws with your ak plates.
Here's why: diesel tractors (over the road semi tractors like a Kenworth) are not even allowed in the CA state border if they do not have a dpf system. They may also require SCR system too. Doesn't matter what state they are registered in, who is driving it, who owns it, or why it is crossing the border.
If they can enforce this law in CA then they can easily apply that law to POV's. I'm not saying that it's true or that you would be okay, but I am saying that the laws currently on the books there certainly point in the direction you don't want to go.
Old Jan 4, 2015 | 08:30 AM
69cj's Avatar
69cj
If you move to Ca. and try to register a deleted truck it will fail. If you try to trade it in, we just got the wife a new car, you now have to sign a declaration that the smog equipment has not been removed, tampered with and is, to your knowledge, fully functional. If your here for more than 30 days, residency, and get pulled over you can get cited for not having the vehicle registered. The cop will ask, esp CHP's.
Old Jan 4, 2015 | 08:37 AM
djousma's Avatar
djousma
Yea that was my thought too. Trade-in is an issue if you were to change your mind on the 20-year thing.
Old Jan 4, 2015 | 09:44 AM
93-331-29PSI's Avatar
93-331-29PSI
Being military you'll have to pass CA emissions tests to get it registered to drive on base. Sucks but Commiefornia is a terrible state to live in when it comes to modified vehicles.
If you delete just keep all your stuff so you can reverse it if stationed in CA. Easy enough to spend a day putting it all back on.
Old Jan 4, 2015 | 11:36 AM
Icthus in AK
Will a tuner allow me to have the emissions stuff "on" to be EPA-compliant and then "off" to bypass or not monitor the DPF, DEF, etc? Even if a tuner doesn't monitor the DPF, won't it eventually clog (choke) with soot?
Old Jan 4, 2015 | 12:12 PM
69cj's Avatar
69cj
If any am equipment pertaining to the emissions is not CARB certified you fail. If it modifies engine performance it falls into this category.
Old Jan 4, 2015 | 12:14 PM
sdetweil's Avatar
sdetweil
No.. the kicker here is that the DPF WILL clog, and ford added a failsafe.. if there is NOT a regen within 600 miles, it forces one anyhow cause some other sensor must be bad, and clogged DPF means no run.
so, IF you take off the DPF then you must disable the failsafe.
if you DON'T take off the DPF, there is not a lot a tuner can do.
you could add a little power, but don't save any fuel, don't avoid regens..
chris023
Jan 19, 2017 04:53 AM
Icthus in AK
6.7L Power Stroke Diesel
27
Sep 7, 2015 06:18 PM
Ricohman
15
May 18, 2015 05:42 AM
952X4
83
Jun 20, 2013 01:52 AM
bavrit
6.4L Power Stroke Diesel
Mar 28, 2013 10:20 PM
