Part Identification
Old Jan 2, 2015 | 09:10 PM
Catch84's Avatar
Catch84
Part Identification
About a week ago I brought some front suspension parts to my house to put in my tumbler to clean them up. At one point I opened the tumbler to see how they were doing and came to the conclusion I was missing a part. I looked all over trying to find it but with about a foot of snow on the ground I didn't hold much hope. I found this picture on another site and if it's one of the members here, thanks! I see his set up only had one, so I figured mine probably did too and I wasn't missing one after all. So the question is, what is it, what function does it perform? Thanks for any help.
Old Jan 2, 2015 | 09:18 PM
HIO Silver's Avatar
HIO Silver
Give us some clues sparky.
All I can tell it's 2WD but what year, engine and is an F100, F250, or F350? PS? PB? Discs?
I don't even recognize those light duty straps.
Old Jan 2, 2015 | 09:25 PM
Catch84's Avatar
Catch84
Ha!! yeah that would be helpful huh? 70 F250 camper special, 390, PS, PB, and discs. I know the part sits on top of where the radius arm and the axle bolts together but I'm unsure as to what it does and why there is only one.
Old Jan 2, 2015 | 09:27 PM
ultraranger's Avatar
ultraranger
Could be wrong but possibly a coil spring spacer? Seems like maybe instig8tr63 (Bobby Ford) posted something similar a while back.
....I see a factory metering valve in the picture for a Bumpside. That means front disc brakes.
Old Jan 2, 2015 | 09:35 PM
Catch84's Avatar
Catch84
Thanks Ultra, I kinda thought it might be a spacer but I wasn't sure why it wouldn't have one on both sides. And just to be clear that's not my pic just one I found on another site.
Old Jan 2, 2015 | 09:42 PM
HIO Silver's Avatar
HIO Silver
Found it... it's 5355 in the 67-69 F350 image below.
..and the light duty straps (which are amazingly straight) are the coil spring straps at the shock tower.
-It doesn't even appear in the 70-72 diagram below.
Old Jan 2, 2015 | 09:52 PM
Catch84's Avatar
Catch84
Thanks to both HIO and ultra, after doing some more searching I believe this is just a shim to make the truck sit level and the reason why I would only have one. Thanks guys! p.s. HIO, if you look on the 70 - 72 diagram you will see those straps are in a different place and are flat. (5B300)
Old Jan 2, 2015 | 10:05 PM
HIO Silver's Avatar
HIO Silver
Domo arigato Catch-san.....! Thanks for pointing it out. I see it now.
Old Jan 3, 2015 | 03:39 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
AR) C5TZ-5355-A .. Shim / Obsolete
Applications: 1965/73 F100/250 2WD
Old Jan 3, 2015 | 02:05 PM
RichS2659's Avatar
RichS2659
For a spring restrainer strap, I would use the 66-69 strap shown in the photo, as they are much stronger than the 70-72 stamped and nutless weak straps. You will have to find them in the JY as I recommended these to Jeff about 6 months ago for somebody, but nobody has these in stock. I broke one on my 72 F-100 back in the 80's so I replaced it with the early style. Too much pre-runner driving, I guess.
Old Jan 3, 2015 | 02:44 PM
JEFFFAFA's Avatar
JEFFFAFA
True story Rich. I remember that. I also remembered it as 66/69 but this is what I'm reading.
66/71 F100/F250 (4X2)..before serial #L80,001..upper..C6TZ5B300F.
btw,JUST IN CASE. 67/71 F350..................before serial #M00,001..upper..C7TZ5B300A.)
And as before, nobody is showing that number on the locators.
Old Jan 3, 2015 | 02:47 PM
JEFFFAFA's Avatar
JEFFFAFA
Instead of "laying frame" it sounds like you're "hanging axle".
Hooter1966
May 14, 2019 03:45 AM
Norcalhal
Aug 19, 2018 07:54 PM
asrfixer
May 22, 2018 09:22 AM
jryan23
Apr 19, 2018 03:02 PM
Lunar Ranger
21
Sep 4, 2011 09:22 AM
