Zf5 overdrive
Old Jan 2, 2015 | 09:21 PM
Macrobb's Avatar
Macrobb
If you can find/afford it, a GVOD is a really nice way to go -- you can't use it in 4x4, but when are you going over 60MPH in 4x4 anyway? You aren't even supposed to go over 35(but I'm sure we all do it anyway)!
The GVOD mounts to the back of the transfer case, and is electrically controlled with a solenoid. You just have a little switch(in my case, on my gearshift) and turn it on and off at will.
I really like it because it gives me a good 6-8 usable gears for towing; when not, you'll never use it for anything other than double-overdrive.
In double-overdrive, you're running about 1650RPM at 60MPH, and it's really nice and quiet. Note, though, that your turbo won't really do much at that RPM, so you have to downshift to get any real passing power. At 70MPH, you're good in double-over power wise.
As far as I'm concerned, for a tow-rig/daily driver, the GVOD is near indispensable. For a DD that won't tow, just go with 3.55s.
Old Jan 2, 2015 | 09:25 PM
tristen f250's Avatar
tristen f250
That's a good idea and about going over 40mph or whatever it was I live up north so if I need it then it will get used but you are right
Old Jan 2, 2015 | 09:45 PM
Macrobb's Avatar
Macrobb
I just drove at 60 in 4x4(with the transfer case in 4x4 as well; otherwise it doesn't matter); it works, but I'm sure it's hard on the front transfer case and such.
Usually, though, you only need 4x4 when starting out, turning or going through really bad conditions, and can just drop the transfer case into 2x4(leaving the hubs locked in) any other time.
With the transfer case in 2x4(and the hubs locked), you can go any speed(and engage the GVOD if you want; it's only when you engage the transfer case(and put power to the front wheels) where you need to be careful about speed and /cannot/ engage the GVOD
tristen f250
So anyone know of a GVOD brand that works with the zf5 or would I need to find out the model of transfer case
Old Jan 2, 2015 | 10:34 PM
Macrobb's Avatar
Macrobb
GVOD = Gear Vendors Overdrive. GearVendors is the company that makes them.
The Overdrive unit is the same across all applications, but has different couplers for different transmissions. If you find one someone was using on a ZF-5, great! Otherwise, you might have to find the correct coupler for the application. GV sells them, but they are $$$. I've seen one guy making custom/knock-off couplers on Ebay, which might be a source as well.
Also, the driveshaft will need to be shortened to make it work.
In my case, my dad had bought mine new for another vehicle with the ZF-5, so I was able to get the entire thing and place it in my truck without hassle. I can't help you with the experimentation/modification aspect, as I've not had to do it yet.
Old Jan 2, 2015 | 10:43 PM
tristen f250
Well thanks for all the help I think I got all the info. I knew that gvod meant gear vendor overdrive but didn't realize that was one company so learned something new lol.
Old Jan 3, 2015 | 12:24 PM
Ford F834's Avatar
Ford F834
The GVOD for a 4x4 needs to match the transfer case, not the transmission. Most of the ZF-5 IDI 4x4's that I have seen came with a Borg Warner 1356 transfer case. Check to be sure though, especially if your truck is not a US truck, and to make sure no one changed it etc., this should help to figure out which one you have. I agree, 4.10 gears in these trucks need double overdrive at highway speeds, or re- geared to 3.55's.
Ford Transfer Case Identification
Old Jan 3, 2015 | 12:45 PM
tristen f250
I'd have to look into it like I said earlier I'm not around the truck at the moment but I'll take your work for now and this truck was in the family so it's stock from factory minus the turbo. Here's just a random question to top it all off, anyone know the gear change in the transfer case for 4 low?
Old Jan 3, 2015 | 01:08 PM
Ford F834's Avatar
Ford F834
The Borg Warner 1356 is geared at 2.69:1 in low range.
Old Jan 3, 2015 | 01:17 PM
tristen f250
Well thx for the help. All my questions have been answered
happycamper247
16
Mar 14, 2008 03:27 PM
Barehuggs
Nov 21, 2006 07:33 PM
fishindave11
Bronco II
May 14, 2005 01:10 AM
plugugly
Aug 21, 2004 08:28 PM
Jim McCarty
Jul 21, 2003 11:08 PM
