Torque Converter for Light Duty
Getting ready to replace the torque converter - rattling noise, goes away in neutral with TC locked.
Drive 5000 miles a year 80% city and do not tow. No mods, stock tranny 160k.
No garage to fit the truck so outsourcing to a tranny shop got $600-$700
quotes with rebuilt cheapo single disc converter (total cost)
Is it really worth to upgrade to 3-disc? Stock one 1 disc lasted 160k...
No $1200 billet nonsense please
Is this design issue repaired during rebuild?
What is the life expectancy of a cheap reman converter? Mind you for me 50,000 miles is 10 years so as long as these things can maintain integrity and not blow up that works for me.
I personally feel the stock stall speed is a bit too high for these engines. I prefer a modified TC with a lower stall speed. Cost is reasonable.
Ford Torque Converters Phoenix by Roadrunner Converters Arizona 602-437-2301
The Tow Master is just under $350. Add $90 to that if you want multiple clutch disks. Just giving you options in case you are interested.
What do you think about these guys? They're 10 miles from my house AND pickup price is $198.
{edit - just noticed Pikachu beat me to it haha}
http://www.ebay.com/itm/FORD-4R100-TRANSMISSION-REBUILT-TORQUE-CONVERTER-GROB-COVER-DIESEL-FM64R-/350165366710?pt=Motors_Car_Truck_Parts_Accessories&hash=item51877b77b6&vxp=mtr
I've never heard of those guys but since they are local to you then you might want to pop on by and see what they are about. If their workmanship appears to be high quality and they have confidence in their product then I'd give them a try. Generally speaking, I prefer to spend my money at local shops provided the quality and value meets my needs. Plus, you might get good customer service in the event you do have an unforeseen issue.
The link that I posted earlier is for a shop that is only 2 or 3 minutes from my work so that is the main reason I use them.....plus they came with recommendations from others that I know so that played a major part in my decision making as well.
Those TC units should work fine in your trans. If not, then you have other pre-existing conditions going on in that unit.
Thanks for recommendations gentlemen. I think I will pull the trigger on that exact one that Pikachu has.
Thank you for your input!
4EXTRDR
11-29-2012 01:09 PM
Motorhead-42
05-14-2007 09:46 AM
