Sponsored by: Real Truck
Dome lights
Old Jan 1, 2015 | 06:46 PM
superduty2001's Avatar
superduty2001
Dome lights
Have a 2012 350 cclb 4x4 6.7 lariat, interior lights don't work. Not with any door open, Not with switch. map lights work. We've checked every fuse in cab and under hood. Any ideas what to check now ?
Old Jan 2, 2015 | 01:41 AM
akbossman's Avatar
akbossman
not sure
maybe the switch is shorted, sticking or not grounded.
Old Feb 22, 2015 | 07:46 AM
scottvet's Avatar
scottvet
Did you ever get this fixed? I'm having the same problem with mine
Old Feb 22, 2015 | 07:55 AM
Platinum08's Avatar
Platinum08
Light bulbs burned out or bad?
Old Feb 22, 2015 | 07:59 AM
scottvet's Avatar
scottvet
All light bulbs work. The individual switches on the actual lights work. When any door is open the interior lights and cargo light do not come on. The manual dimmer switch will not turn on the lights either.
Old Feb 22, 2015 | 08:24 AM
meborder's Avatar
meborder
https://www.ford-trucks.com/forums/1...t-display.html
check out post #6.
sounds like the 'police dark mode' might be turned on, which has to be changed at the dealership
Old Feb 22, 2015 | 08:40 AM
scottvet's Avatar
scottvet
I'm not sure if that is it. All the outside lights come on normally when each door is opened, only the interior and cargo light do not come on. The lights used to work, but all of a sudden a couple weeks ago they stopped working.
Old Feb 22, 2015 | 08:42 AM
cfesting's Avatar
cfesting
I like it. Check to see if the "dummy chime" works when you open the door - like if you left your keys in the ignition or lights on. Those will still work if light outage is due to Police Dark Mode. Otherwise, maybe the door switches are bad?
However, the "The manual dimmer switch will not turn on the lights either." is throwing me off. I think that should still work with Police Dark Mode. Should also work if door switch issue. Maybe the dimmer is the problem?
Old Feb 22, 2015 | 08:49 AM
scottvet's Avatar
scottvet
I am kind of leaning towards the dimmer switch, but I haven't been able to find a good wiring diagram for it. Unfortunately I don't have my tester w/ me so I can't confirm if fuse 12 has power to it, but I know the fuse is good as I tested it in another circuit
7.3 Ex
Mar 4, 2011 11:59 AM
GreaseMonky
Feb 28, 2011 04:49 PM
Quick69
Aug 31, 2010 10:02 PM
Glockem45
Oct 24, 2005 12:13 PM
zoomx2
Aug 28, 2004 01:04 AM
