Sponsored by: Real Truck
Ceiling lights not working, what gives?
Old Oct 21, 2005 | 09:02 AM
Glockem45's Avatar
Glockem45
I have a 2004 PSD CC. The interior lights both up front and in the back work, when the doors are open, and when I hit the interior switch on the dash. However, they don't work when you flip the switch at the actual lights on the ceiling, on either the front ceiling lights or the rear ones. What does this mean, the swithes are bad, or what? Thanks.
Old Oct 24, 2005 | 11:45 AM
Glockem45's Avatar
Glockem45
Any ideas guys?
Old Oct 24, 2005 | 11:58 AM
Hockycop's Avatar
Hockycop
The lights on the switches at the ceiling work off a separate fuse. I had the opposite problem. Those lights worked fine, but the cargo light and the int. light would not come on. I fixed it by replacing the relay under the dash in the fuse box. You probably have no power to the switches. Check your fuses........
Old Oct 24, 2005 | 12:13 PM
Glockem45's Avatar
Glockem45
Ok, I will check that. Thanks.
