80-97 cabs
Old Jan 1, 2015 | 08:29 AM
Fordbro's Avatar
Fordbro
80-97 cabs
I have an 83 F250 with a 460 currently in it. The motor is getting up there in miles and is starting to give me problems. I've been doing some research into how different the cabs between the years of 83-97 are because I'm considering buying a 94-97 powerstroke truck and then swapping my 83's nose and bed onto the new truck once I've stripped the older nose and bed off. I'd like to leave the cab alone so I don't have to mess with the dash and wiring. Is it possible to bolt the 83 nose up to the newer cab? Anybody done it before?
Old Jan 1, 2015 | 09:33 AM
tjc transport's Avatar
tjc transport
i ain't rite
welcome to FTE.
yes it can be done fairy easy.
the big difference between the years is front end and bumper mounts.
years ago at the body shop we put a 92 nose on a 85 truck because the owner wanted the newer look.
it will take a little work to get everything perfect, but not a real hard job.
just remember, you need to use everything from the year nose you want to run. the radiator support is the key to making things work properly, because that is what the fenders and grill mount to.
Old Jan 1, 2015 | 09:45 AM
Fordbro's Avatar
Fordbro
So does that mean I'd have to fabricate the rad support to fit the powerstroke radiator? If I remember correctly the powerstroke rad supports don't go straight across on the bottom but have a bump out on them. Am I correct?
Old Jan 1, 2015 | 10:25 AM
tjc transport
i ain't rite
yup, you would either have to find a diesel rad support for the year nose you use, or fabricate the gas one to fit.
Old Jan 1, 2015 | 11:04 AM
Diesel_Brad's Avatar
Diesel_Brad
IF you find a 80s diesel rad support(good luck) that would house the power stroke radiator(or just use the 80s radiator)
Butchashop
22
Feb 4, 2014 08:22 AM
jays92
Aug 26, 2013 01:16 AM
marky55
Mar 11, 2009 03:19 PM
mrpontiac66
Oct 10, 2008 09:48 AM
lks dcvn
Oct 13, 2005 02:53 AM
