front clip interchange?
Old Oct 12, 2005 | 07:12 AM
lks dcvn's Avatar
lks dcvn
Will most front clips interchange between models for 1973-1977? I have a 1975 F250 and I found a clean 1974 1 ton stake truck front clip complete. Will this be a direct bolt up?
Thanks in advance-
Tom
Old Oct 12, 2005 | 08:05 AM
2tone73's Avatar
2tone73
The only thing that changed for 1973 to 1979 ford trucks was the grill shell and inserts. It will fit!
Old Oct 12, 2005 | 10:11 AM
73Custom's Avatar
73Custom
There is one other difference to watch for. The radiator support could be different depending on the radiator it was made with. Some had a smaller opening and some had different mounting brackets, but this can all be changed with a little work and thought...
Marty
Old Oct 12, 2005 | 10:23 AM
plowpusher's Avatar
plowpusher
if you can find them get some 77-79 front inner fender wells they are plastic and will keep 90% of the crud off you new front clip and the bolt right in. They really help preserve the core support, metal inner fenders,cab floor,door posts, and cab mounts
Old Oct 12, 2005 | 09:54 PM
hotroddually's Avatar
hotroddually
i have the plastic inner fender linings in my 74 4x4 your right, they really keep the muck out.this was a good upgrade in my opinion.-billy
Old Oct 13, 2005 | 01:13 AM
amish_dan's Avatar
amish_dan
would those plastic linings help reduce road noise at all?? It would be nice to quite those big tires on the freeway
Old Oct 13, 2005 | 02:53 AM
Slow's Avatar
Slow
I doubt it, but they do keep the sound of rocks hitting the panels down
