2015 BS thread. Bring it!
Old May 8, 2015 | 01:46 PM
  #9121
kjvforme's Avatar
kjvforme
Hook up a amp meter between the battery and the clamp and start pulling fuses, when the load drops walk your source.
Old May 8, 2015 | 01:53 PM
  #9122
Jigger2020's Avatar
Jigger2020
Thats exactly what I was gonna say....... ^^^
Old May 8, 2015 | 02:06 PM
  #9123
kjvforme's Avatar
kjvforme
Like minds
Old May 8, 2015 | 05:47 PM
  #9124
Jigger2020's Avatar
Jigger2020
Yup, thats one way to look for a drain on the batteries
Old May 8, 2015 | 08:15 PM
  #9125
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
Maximum Security Chicken Coop finished...........
Old May 8, 2015 | 08:30 PM
  #9126
Jigger2020's Avatar
Jigger2020
Well done Roy, chicken soup coming up
Old May 8, 2015 | 08:43 PM
  #9127
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Fried eggs........
Not planning to cook Snow or Carmen or Black or Tiger
Old May 8, 2015 | 08:45 PM
  #9128
Jigger2020's Avatar
Jigger2020
You never should have named them, now you're attached
Old May 8, 2015 | 08:51 PM
  #9129
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
True......They are little Theresa's pets and lynn's farming project.......No chopping heads off....
Old May 8, 2015 | 08:54 PM
  #9130
Jigger2020's Avatar
Jigger2020
I understand, I havent got the heart to kill anyway
Old May 8, 2015 | 09:29 PM
  #9131
sky Cowboy's Avatar
sky Cowboy
Suddenly i am craving an omelette
Old May 8, 2015 | 09:35 PM
  #9132
Jigger2020's Avatar
Jigger2020
Yes I'm getting hungry too, lol
Old May 8, 2015 | 09:37 PM
  #9133
Seabiscuit-P3's Avatar
Seabiscuit-P3
Veteran: Navy
Veteran: National Guard
Good evening Oregon and everyone everywhere else. Home for the evening. May even work up the energy to go out and mow some lawn............................................or not!
Originally Posted by Hobby welder
Any idiot lights staying on? dome light? short?
Morning folks!
Can't find a short, lights have a 20 minute cut off after ignition is shut off so even if the dome or even headlights were left on, they would be cut off after 20 minutes. Double checked and the 20 minute timed relay is working.
Meter isn't revealing anything. Had the charger on in automatic mode, 2 amp most of the day hoping to catch the needle bouncing on the gauge, but it stayed right at 100% charge all day unless I turned a light on for a test.
I still think there is something going on with one of the batteries or there might be some kind of drain going on through the starter relay, although the meter is not showing any kind of voltage across the relay.
I think the next shot will be to make sure the batteries are fully charged and then unplug the cables and let it sit for a couple of days...if I can figure out when I can go without it for a couple of days.
What really gets old is having to reprogram all of the darned presets on the am/fm radio.
Old May 8, 2015 | 09:46 PM
  #9134
Jigger2020's Avatar
Jigger2020
You're right Jim, it could be the batteries wont hold a charge...
Old May 8, 2015 | 10:02 PM
  #9135
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Internal short in the battery........?
