What should the Idle be on a 92' 460?
Mine starts up cold to about 1200 then drops to about 700 in about 3 seconds. no high idle when cold and sometimes the idle will be around 650. is that too low? I see some videos where they idle around 1000 in park.
New IAC, screw hasn't been and TPS return voltage is about .9v. It runs fine just idles really low. Usually in gear at stopped at signal it's like 550/600
