wider
Old Dec 29, 2014 | 08:40 PM
zachbrown0413's Avatar
zachbrown0413
wider
This might be a dumb question but I see trucks where they aren't lifted much and the tires look like they are out so wide. Idk how to explain it. They look like the front and rear end are wider than the rest of the vehicle aND sticks out farther. Andybody have an idea of what this is or how to make my truck look like that? I assume it's some type of extensions for the front and rear end
Old Dec 29, 2014 | 10:09 PM
85e150's Avatar
85e150
It usually is the result of wheels with less offset than stock, and sometimes those are wider wheels to boot.
More here:
http://www.tirerack.com/wheels/tech/...jsp?techid=101
Watch what you do in this department. Too much negative offset, which will result in the "wheels out" look, can cause bearing issues and handling issues like twitcy steering and difficulty controlling the vehicle during hard braking or if you blow a tire up front.
Old Dec 30, 2014 | 11:51 AM
bbender85's Avatar
bbender85
are you talking about prerunner trucks?
Old Dec 30, 2014 | 11:57 AM
zachbrown0413
No I've seen Tahoe look like that and some other vehicles. I think it's wheel spacers
Old Dec 30, 2014 | 02:53 PM
danorules's Avatar
danorules
Could be spacers but that usually only buys you an inch or two. Changing the offset and rim width will really set you up with a wide stance. The factory rims are 6" wide with a +44 offset so you could go crazy with a 12" rim and a - 30 offset and really stick those sneakers out of the wheel wells
Old Jan 1, 2015 | 07:29 AM
60DRB's Avatar
60DRB
- Some states require wheels & tires to remain within the wheel wells, or they ticket/fine you.
- I thought those "extended" wheels caused extra wear on the wheel bearings?
Old Jan 1, 2015 | 09:53 AM
zachbrown0413
I think I read that somewhere. And if u think about it that makes sense. They don't make spacers for my truck anyway because it seems like my truck is the only one with 7 lugs.
Old Jan 2, 2015 | 12:45 PM
18wheelin's Avatar
18wheelin
7Lugs
Yes some states do require the tires to be inside the wheel wells. If you have 7 lugs you have a heavy half just like I do. I love mine!!
Old Jan 2, 2015 | 12:47 PM
zachbrown0413
I love mine too but it's a pain to find rims for it haha
Old Jan 3, 2015 | 06:05 PM
18wheelin's Avatar
18wheelin
Yep sure is. I did see some on eBay. I think I am just going to blast my stock steel rims and powder coat them black.
Old Jan 3, 2015 | 06:08 PM
zachbrown0413
That's what I did to mine I painted them matte black with this stuff called plastodip I got it at pep boys for about 5 dollars a can. It stays on great but if u don't want it or like it u put a nick in it and it peels off like tape. It's good stuff
Old Jan 3, 2015 | 06:09 PM
zachbrown0413
Plastidip.
ufvj217
Nov 29, 2015 02:40 AM
MaxPowers
46
Aug 12, 2014 06:40 PM
reed1951
19
Jul 1, 2011 08:23 PM
SMF Speed&Custom
Nov 19, 2010 05:21 PM
snoVVman
Sep 6, 2005 12:03 PM
