Brake Issue
Old Nov 16, 2014 | 06:46 PM
gordo777's Avatar
gordo777
Brake Issue
I replaced the front and rear rotors and pads on my 2008 F150 Screw 4x4.
The back passenger brake then starts to grab after a short awhile.
The rotor is very hot compared to the rest of the rotors.
I replaced the emergency brake pads and hardware and backed them both right off.
I removed everything and greased the sliders with high temp silicone, thinking the caliper was binding.
Still sticking....the caliper moves freely (in that it pushes back no problem with a c-clamp.
I even had them look at it at my local mechanic. They test drove it (twice) and couldn't find anything wrong!! Ugh!!!!
Any help would be greatly appreciated.
Old Nov 16, 2014 | 08:13 PM
P.Bronner's Avatar
P.Bronner
Sure sounds like the piston is sticking in the caliper.
Old Nov 16, 2014 | 08:19 PM
JWC 3's Avatar
JWC 3
Or a bad hose . The pins are free ... correct ?
Old Nov 17, 2014 | 08:06 AM
gordo777's Avatar
gordo777
The pins are free on both sides...I originally used suspension grease on them, but decided after all the trouble I'm having (and the little trouble it takes) to remove them, clean them up, and apply high temp brake lube.
With regard to the caliper, does anyone know if these are serviceable?
The older style used to have solid metal pistons, but I believe the newer ones are made from hardened plastic (phenolic).
Regarding the hose....the line looks fine. Its not kinked at all...could it still be a problem?
Old Nov 17, 2014 | 06:34 PM
j mcm's Avatar
j mcm
The hoses go bad internally and do not release the pressure. Sounds like that may be your issue.
Old Nov 17, 2014 | 07:27 PM
gordo777's Avatar
gordo777
Many thanks for the advice....I'm gonna try replacing the hoses.
Fingers crossed. Will update my results.
gordo777
Old Nov 17, 2014 | 08:22 PM
P.Bronner's Avatar
P.Bronner
I don't think you can buy rebuild kits for the calipers anymore. Good luck with the hoses but I think a caliper is going to solve the problem. Also, I think most newer calipers have ceramic coated pistons which have a plastic-like appearance and feel. They would have to be some type of metal due to the temperatures involved.
Old Nov 18, 2014 | 06:15 AM
gordo777's Avatar
gordo777
Hmmmmm....interesting!
Sure wish they'd leave well enough alone, but then again that's how they make the $$$ I guess.
Thanks again for the help! Greatly appreciated!
Old Dec 17, 2014 | 09:40 AM
gordo777's Avatar
gordo777
Just to update on my success.....I replaced both rear hoses...one of the easiest jobs I've done! The old parts came off easy and the new ones went on even easier.
Bled the brakes out....and problem solved....for about a day!!!
Repalced the calipers on both sides (getting to be an expert at this now!)
Problem completely solved! Haven't had an issue since changing the calipers.
It's been about two weeks now and all good to go.
Many thanks for the help here fellas.
Cheers
Old Dec 17, 2014 | 02:08 PM
bbender85's Avatar
bbender85
THANK you for following up, i think i am currently having the same issue:
https://www.ford-trucks.com/forums/1...ooks-good.html
here i was thinking about doing hoses first.. maybe i'll go straight for the caliper (can get it for $30 anyways).
reps sent for the follow up!
Old Dec 29, 2014 | 09:17 AM
bbender85's Avatar
bbender85
finally replaced my caliper over the weekend and so far it seems to have fixed the problem.
what is the pedal supposed to feel like on these trucks? the brakes work well and the pedal seems to feel fine, but if i keep pressure on it it seems like it goes down slowly still. seem right?
Old Dec 31, 2014 | 09:25 AM
Shovelhead 93's Avatar
Shovelhead 93
I had an issue with front calipers sticking on my 06, I changed flex lines and calipers, issue is gone.
Old Dec 31, 2014 | 04:24 PM
db_tanker's Avatar
db_tanker
bbender,
sounds like you either have air in the system or a possible master cylinder issue with internal bypass. give the system a good bleed starting at the back right corner and work your way up. if that doesn't fix it then probably going to be the master cylinder.
Old Jan 4, 2015 | 01:50 PM
2004 xlt 5.4's Avatar
2004 xlt 5.4
Mine is the same according to ford that is nomal
Old Jan 4, 2015 | 02:04 PM
60DRB's Avatar
60DRB
...I don't believe "Ford" says that. Maybe one idiot you talked at a Ford place said so...
After initial brake pressure is applied, the resistance should remain pretty constant (not continuing to depress/sink). That would indicate air in the system or a faulty master cylinder or brake booster, etc. As previously pointed out above.
