Remove oil pan 390
Old Dec 26, 2014 | 09:19 PM
BOSSY's Avatar
BOSSY
Remove oil pan 390
Do I have to lift the 390 motor in my 1973 Ford F-100 2wd.? Either the pan gasket or rear main is leaking. BOSSY
Old Dec 26, 2014 | 11:10 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Yes, you'll need to jack the motor up.
Remove the fan shroud, drain the oil, unbolt the motor mounts from the perches.
I'm sure some will cringe at this but I used a hydraulic jack under the harmonic balancer to jack the engine up. Place some 2X4's between the mounts and perches. Unbolt the oil pan and drop it down on the crossmember. Get your hand up in the crankcase and unbolt the oil pump and let it drop into the pan then remove the pan.
Now you have access to change both the pan gasket and rear main seal.
BTW, welcome to FTE. Lots of good, knowledgeable people here.
FordRacer69
Mar 4, 2023 04:41 PM
Ol Red 75
Sep 15, 2011 11:23 PM
michaelbrainardatwor
Mar 22, 2004 11:26 AM
ford390gashog
Jan 21, 2004 08:58 AM
offroadguy
May 9, 2003 11:44 PM
