What gearing came in the 94 rangers 2 wheel drive and 4 wheel drive. I have a 2 wheel drive with 31s but it dosnt like the 31s to much. Wanna change gearing.
These trucks came with everything from 3.08 to 4.56 gears, post up the axle code found on the drivers door pilar or compare to the data found here..Ford 7.5 & 8.8 Inch Axle Tag & Door Codes
Don't forget, that a '94 is 20 years old! A lot can happen in the past 20years.... such as an accident or something to cause the driver's door to have gotten changed or the rearend might have gotten changed, which would indicate one thing but it's not.
You can block the rear up mark the driveshaft and a wheel and turn the wheel. Count number of times the drive shaft goes around for 1 wheel revolution. It will be close to give you an idea.
Note: Both rear wheels have to be turned together. If one wheel is on the ground, the ratio will be off by a factor of 2.
Just a heads-up for those contemplating changing from a 7.5 to an 8.8 rear end: be aware that the 8.8 generally comes with larger diameter drum brakes which can lead to rear brake lock-ups, under even moderate braking conditions.
My '91 long-bed came with the 8.8 and I ended up cutting back the shoe material half-way on both rear brakes to stop the locking. If I had the super cab (which is heaver) instead, then I may not have had a problem.
My 93 2WD XLT supercab came with 3.45 gears and 225-70-14 tires, great for gas mileage in OD. I put a 3.73 rear end under it a year or so ago due to improper towing and it does fine, but about 1-2 mpg less at speed in OD. I can't imagine anything less than 3.73 or 4.11 if you want to push 31 inch or larger tires. Decent used rear ends are not that hard to find, just takes some leg work. My swap cost me $250, sourced and hauled it from the junk yard to the mechanic who did the swap for $150 and kept the old toasted rear end for scrap.
