Dash lights fluctuating brightness
Old Dec 26, 2014 | 01:12 PM
rews2's Avatar
rews2
Good morning and hope everybody had a good Christmas.
I tried to search posts for this problem but didn't come up with the result I wanted.
I thought I saw a post here at one point on the dash lights becoming brighter as the rpm went up and dimmer at idle.
Is there a relay or some sort of voltage booster I can add? Dash is all stock.
Old Dec 26, 2014 | 01:32 PM
Gembone's Avatar
Gembone
do the 3G swap and it will eliminate this. The pick a parts have plenty of donors for this. costs about $30.
first 3 link here cover the swap, https://www.ford-trucks.com/forums/1...l#post12243508
also, clean and secure all grounds.
Old Dec 26, 2014 | 01:52 PM
rews2's Avatar
rews2
Perfect exactly what I need. Much thanks.
Old Dec 26, 2014 | 08:36 PM
Binkowski's Avatar
Binkowski
check headlight switch
Do make sure to check the headlight switch. There's a spring that goes all the way around for adjusting the brightness and the spring is prone to breaking but with all the bouncing may still make a connection. My dash lights were doing just what you described and it was that spring on the headlight switch. Search the threads about removing as there are a couple of tricks to get the **** disconnected, etc.
Zachthemoo2
Sep 18, 2014 11:34 PM
1972RedNeck
Dec 25, 2013 01:37 PM
Reddman
Oct 16, 2013 10:21 AM
goodfoot
Jan 2, 2002 06:04 AM
john_anderson03
Electrical Systems/Wiring
Mar 15, 2001 07:58 AM
