No dash lights
Old Oct 15, 2013 | 04:17 PM
Reddman's Avatar
Reddman
No dash lights
My dash lights are not working all the time. My guess is it's from a bad ground since every now and then 1 might come on for a while. Is there anything I should keep my eyes on when I open the dash up? Is there any tricks to keep them working? 78 F350
Thanks for any advise.
Reddman
Old Oct 15, 2013 | 04:32 PM
fmc400's Avatar
fmc400
MSEE
The next time it happens, measure the voltage on BOTH sides of the dash illumination fuse and report your results.
Old Oct 15, 2013 | 05:22 PM
blackjack33's Avatar
blackjack33
Try this...
Pull the headlight switch out of truck, inspect and clean as needed.
Look at the contact that "rides" on the rheostat spring, make sure it's free of corrosion.
I recently went through a similar situation on my truck. I cleaned the contacts thoroughly, reinstalled the switch and the problems went away.
Old Oct 16, 2013 | 10:21 AM
Reddman's Avatar
Reddman
Thanks guy's. Hopefully I can take a look at this Saturday. This will help shift my memory. I had this same problem with my hi-boy about 20 years ago & can't remember what all I did to resolve it.
Reddman
Dec 9, 2010 01:53 AM
cumminsdieselfreak
16
Dec 29, 2007 02:25 PM
sixpacpikupman
1983 - 2012 Ranger & B-Series
Dec 20, 2005 07:38 PM
TxBrokenarrow
1978 - 1996 Big Bronco
Sep 15, 2004 04:06 PM
aintskeered
Electrical Systems/Wiring
Dec 19, 2001 03:42 PM
