dash lights
Old Dec 20, 2001 | 11:53 AM
goodfoot's Avatar
goodfoot
dash lights
My '74 F-100 suffers from dim dash lights. I changed out the light switch on the dash in hopes that the rheostat was the culprit and not allowing full voltage to the bulbs but the new switch does no better. Does anyone have any ideas. Thanks and Merry Christmas.
Old Dec 20, 2001 | 01:20 PM
73Custom's Avatar
73Custom
dash lights
[font color=red size=2]My '73 had the same problem, they only litup a dim green. So I took the dash apart and found the problem... There are green plastic "caps" that cover the light bulbs to make it a green tint. My "caps" had gotten very dark and clouded over the years. So I removed them and WOW! what a difference, way brighter! The light is white now (which I like better), but you could get any color bulb you want - blue, green, red.
Just pull the guage panel out, and remove the screws from the back and pull the back off. Then you will see the green "caps" inbetween the guages, they just snap on - pull them off. At this time I wiped some of the dust out and used some orange paint to repaint the faded guage pointers. Then just reassemble.
Marty
Old Dec 20, 2001 | 03:49 PM
skud's Avatar
skud
dash lights
My 77 F-150 had the same problem except it was the headlight switch. If i moved it very carefully, it would go brighter, but only in a particular spot. Eventually I just replaced the switch ($12 at a local shop).
Hope this helps
Later
Riley
Old Dec 20, 2001 | 06:17 PM
79fordslug's Avatar
79fordslug
dash lights
I reccomend following the above two posts but I would also clean the copper wiring that connects all the bulbs. After years of corrosion in air, the wires can lose a little conductivity. Good Luck!
Old Dec 21, 2001 | 05:27 AM
goodfoot's Avatar
goodfoot
dash lights
Thanks for the help. Since the dash switch didn't do the trick I'll be takin' them bulb covers off that I didn't know about. I hate to remove their little green covers in the near heart of winter but at least they reside in Florida
Old Dec 24, 2001 | 05:32 AM
Trail_Rider's Avatar
Trail_Rider
dash lights
[updated:LAST EDITED ON 24-Dec-01 AT 06:32 AM (EST)]Marty is absolutely right. Get rid of those stupid covers, and you'll be good to go.
Trail Rider
Old Dec 29, 2001 | 12:55 AM
motorhead's Avatar
motorhead
Post dash lights
Old Jan 2, 2002 | 06:04 AM
goodfoot's Avatar
goodfoot
dash lights
Thanks to this board I can now see my gauges after sunset. My dash lights had blue covers and after popping them off and reinstalling the dash panel over the holidays, yerika I can read 'em at night. I really appreciate the help.
Dizz88
19
Jan 9, 2020 03:20 PM
cadunkle
Jul 8, 2013 08:46 PM
ReBilld
Mar 26, 2012 04:34 PM
steedracer
Electrical Systems/Wiring
Nov 11, 2010 10:31 PM
jayhawkfan
1983 - 2012 Ranger & B-Series
Feb 19, 2004 03:29 PM
