Year Model???
Old Jan 4, 2015 | 03:10 PM
  #31
Jolly Roger Joe's Avatar
Jolly Roger Joe
Originally Posted by Dgrant51
What do yall make of it?
F1R1KC26314
F1 = F1
R = V8 engine
1 = 1951
KC = Kansas City plant
26314 = 26,314th built that year
Do you also have this number stamped in the frame near the right motor mount? They're sometimes under a lot of grime, and hard to find.
Last edited by Jolly Roger Joe; Jan 4, 2015 at 03:29 PM. Reason: I originally put the wrong engine type in the post.
Old Jan 4, 2015 | 03:15 PM
  #32
harleymsn's Avatar
harleymsn
Thats one thing working on the cab that I noticed is I dont think the cab is a 51 it has back cab corners like a 53. Im not to concerned about the title I know the previous owner hes just an older guy and any issues getting the title he will assist with.
I am really puzzled where you keep coming up with '53. Nothing about that truck says 1953.
Old Jan 4, 2015 | 06:24 PM
  #33
Ibuildmyown's Avatar
Ibuildmyown
You have a 1951 F 1 The tag is on the firewall. A late 1951 and 1952 the tag is on the glove box door . The number you want is on the right front frame on the top . Use some emery cloth or sand paper to find it . It's not stamped very deep. Texas is not hard to get a title. Now, about those front springs, are they in good shape, ? If so I would be interested in them, thanks.
Old Jan 4, 2015 | 07:05 PM
  #34
Jolly Roger Joe
Actually, that pic is of the Patent Data Plate on the firewall. The plate on the glove box looks a lot different. But I still think he should find the number on the frame.
Here's my Patent Data Plate. Only the top numbers are stamped in and the rest is painted or silk screened on. It was wiped clean and I had to replace it.
Here's my Glove Box tag. My truck was built in August 1950. Some time after that, the 1951 glove box tags changed.
Name:  Before purchase  17.jpg
Old Jan 4, 2015 | 07:30 PM
  #35
AXracer's Avatar
AXracer
ONLY the stamp on the frame is the legal serial number, if it matches the rating plate pictured or not doesn't matter rating plates can and often are switched. Only the frame stamp defines the year of the truck, doesn't matter what year the sheet metal is. Don't play russian roulette with your truck, get it titled in your name before you spend another day or dollar on it.
Old Jan 4, 2015 | 07:47 PM
  #36
Jolly Roger Joe
Couldn't have said it better.
Old Jan 5, 2015 | 05:13 PM
  #37
Dgrant51's Avatar
Dgrant51
Thanks for the help guys I havent been to work on it in a little bit I will look for the number on the frame see if they match and I am working on title now. Im not real savy on these trucks and dates I was looking at the wrong thing when I said 53.
Old Jan 5, 2015 | 06:01 PM
  #38
Jolly Roger Joe
This is where my frame stamp is located just for a reference. And mine has the 226 6 cylinder, so don't let the old fuel pump confuse you. That's the frame by the right motor mount.
Old Jan 8, 2015 | 10:54 PM
  #39
Moe Craig's Avatar
Moe Craig
Dgrant51, Sorry if I got on you about the year of your truck... Just wanted to find out how it's coming? Where you able to get it in your name?
Old Jan 9, 2015 | 01:09 AM
  #40
ben73058's Avatar
ben73058
Hey Dgrant,
When we went to get the Title in our name here in Austin. We just had a tag in the glove box with the Vin #. The frame where the Vin# would have been was under our nice welded in IFS. All that was required of us was a $2 Vin Verification Form that any inspection place can fill out. They found the nice tag in the glove compartment & didn't look anywhere else & just filled out the form & faxed it in to the DMV.
In our case we had an out of state title & just needed the VIN verification to complete the process. If I were to do this again I would get the title work done BEFORE doing the Independent front suspension & obliterating the vin on the frame.
Good luck over there. Let us know how it goes.
Ben in Austin
1950 F1
Bret Sutherland
67
Aug 8, 2019 12:14 AM
BaggedMerc
Jan 4, 2015 11:30 PM
dixiepc
Dec 14, 2010 11:43 AM
hot-rod
27
Jun 16, 2010 08:23 PM
silvercup_3
Jul 15, 2007 05:39 PM
