would appreciate help identifying year of this abandoned van
where is the VIN located? it could have rusted away for all i can tell. it’s been abandoned since ‘85. Newfoundland and Labrador weather doesn’t take kindly to metals of any kind. 😂 I still see hope in the thing though. engine turned after i pulled the plugs and manually turned it with a breaker bar. was a bit stiff at first, but some Liquid Wrench fixed that.
Last edited by Bret Sutherland; 07-13-2019 at 12:12 PM. Reason: would like to add more text
the windshield isn’t there. i don’t know what you mean by the doghouse, either. i’m confused 😂😂. this seems to be one of my stupid moments
I drove an E300 Supervan for 25 years and had it apart many times.
I also owned many 60's era vans.
My current one is a 2002 E350 15 passenger V10 Club Wagon.
There are multiple places where they stamp VIN's in the frame, as well as the VIN plate at the base of the windshield, on the dash,
That's the intake manifold engineering number. Not the date it was produced. The date code will be a number/letter/number(s) on what looks like a rectangular tag cast into the intake. That a V8 or six ? I can't tell in the pictures.
VIN was behind the windshield sunken in a slot beneath the dash pad on the driver's side. Might also be on the driver's side door jamb. May also have the last numbers of the VIN stamped onto a flat on the rear of the engine block. If that's a 302, the engineering numbers are above the starter, along with the date code tag.
