gauges all reading high
Old Dec 21, 2014 | 03:46 PM
EP145's Avatar
EP145
Hi Guys,
My 73 F100 gauges are all sudden reading very high except the amp gauge. I know there is do-hickey on the back of the cluster does anyone know what it's called and will that cause my problem?
Dan
Old Dec 21, 2014 | 05:55 PM
Blue and White's Avatar
Blue and White
Originally Posted by EP145
Hi Guys,
Dan
The instrument cluster voltage regulator (IVR) regulates voltage to the gauges to something like 5 volts. Failure could cause temp, fuel and OP to read high. It snaps on to the back of the panel with connections like a 9 volt battery. About the size of a thumb tip. Available at most AP stores.... or JY. Once the cluster is out you gently pry the old one out and snap in new. Not hard except the old panel backs can get fragile with time.
Old Dec 21, 2014 | 07:42 PM
EP145's Avatar
EP145
Thanks that's what I needed!
When I was driving home the other morning the temp went up and the oil pressure was higher than normal with it being 40 degrees out side, I was thinking the thermostat was sticking until I filled it up and that gauge read high also.
7oldblue3
Mar 17, 2019 06:28 PM
highway90
Sep 17, 2017 07:41 PM
53redford
Dec 27, 2005 05:57 PM
BJScott1986
Electrical Systems/Wiring
May 5, 2005 11:21 AM
nojeffgordon
Jun 7, 2004 10:07 PM
