dome light stays on
Old Dec 21, 2014 | 03:45 PM
fordboy97's Avatar
fordboy97
dome light stays on
I noticed yesterday while driving down the highway my dome light was on. Both doors were shut and the switch was off but it remained on. I took the bulb out to prevent it from killing the battery. Only thing I saw was the switch on the pass door was stuck closed (pushed in) and when I pulled it out or wiggled it the light flickered. Does it sound like it could be the switch? Everything else works fine
Tanner
Old Dec 23, 2014 | 07:54 PM
87-XL-Squared's Avatar
87-XL-Squared
Welcome to FTE.
IF not the light switch on the dash that manually turns on the dome light, it might be a door switch.
Open both doors, the light should be on.
Close one door the light should be on.
Close the second door the light should be off.
Play with one door switch to determine the one that is bad.
This is dependent on the light switch on the dash not being the culprit.
Old Dec 24, 2014 | 02:06 PM
fordboy97's Avatar
fordboy97
Thanks. I'll look into it a bit more. I've got to get a new door switch anyway since this one is stuck.
Psyclopse
Jul 4, 2014 03:03 AM
fordtruck661
Electrical Systems/Wiring
Nov 21, 2012 10:37 AM
lostin90s
Aug 3, 2007 07:34 PM
cdnfireman
Jan 25, 2007 12:24 PM
choperj
Oct 19, 2003 02:16 PM
