dome light
Old Oct 18, 2003 | 10:42 PM
choperj's Avatar
choperj
dome light
The dome light in my '69 f100 will not go off.............even with the
doors shut...is it because of the colder weather?
I've tried the switches over and over again......is it just the switch?
Old Oct 19, 2003 | 12:57 AM
Kevin Duffy's Avatar
Kevin Duffy
Now when youve tried the switches, manually with the door open does the light go off? If so, your switch needs adjusted, simple box end wrench will do.
Now if it stays on. Either a bad switch or bad ground. If you can get to the switch wires check them out for corrisoin or loose fitting connections.
Old Oct 19, 2003 | 01:22 AM
Jackflack's Avatar
Jackflack
Check your 2 door switches or Your Dimmer switch on your Light switch broke. Those are the 3 things that turn on your dome light.
Old Oct 19, 2003 | 01:29 AM
stepman's Avatar
stepman
Yeah, I would think the light switch. What switches have you been trying?
Old Oct 19, 2003 | 07:46 AM
williamwilliam's Avatar
williamwilliam
I would say the light switch itself. Most of the time when the door jam switches go bad the light will not come on at all.
Old Oct 19, 2003 | 09:42 AM
choperj's Avatar
choperj
I have only tried the door switches.......i have also taken the domelight itself out ..........
I know that the door switch is just a ground itself, but when i took the dome light itself out..every time i would touch the bezel to the sheetmetal that the bezel fits in....the light would be on.....
I'll to try the interior dash light switch.......maybe that will turn the domelight off.........so that i'm not being blinded when i drive at night
-SKIP
Old Oct 19, 2003 | 02:16 PM
BB's Avatar
BB
Hi Skip, the lights switch on the dash does turn the dome light off and on. Rotating the **** fully counter-clockwise engages the switch to turn it on all the time, you'll feel it click. Turn it back to switch it off and only the door switches can turn it back on again.
Barry
hatchetman
Aug 19, 2011 10:20 PM
socalarcade
1983 - 2012 Ranger & B-Series
Dec 18, 2010 09:17 AM
socalarcade
Dec 12, 2010 05:17 PM
cr1391
Oct 30, 2004 10:41 AM
Sedric
Jan 5, 2003 11:06 PM
