89 ranger 2.3 code 28
Old Dec 19, 2014 | 04:13 PM
moneypit79's Avatar
moneypit79
Was driving the truck when the tach quit working,check engine light came on and the truck wouldn't idle.checked codes and got a 28 and an 88.replaced ignition module and passenger side coil.code 88 is gone but truck runs poorly,still no tach and have code 28 still.any ideas please?
Old Dec 20, 2014 | 12:02 AM
87 XLT's Avatar
87 XLT
What is a code 28?
I have an 89 4wd ranger with a 2.3 and a 5 spd manual trany and manual transfer case.
Put a computer on the truck. Returned codes:
86 Vacuum regulator EGR (EVR) circuit failure
28 Hard fault loss of tach rt side: Also, Lose of IDM rt side (I do not know what an IDM is)
33 Low EGR flow
98 Hard fault present: Dtk present (FMEM)/EPC circuit fault
Nutshell:
Starts right up, after rpm settles down (1-2 min), check engine lite comes on and tach dies. At this point if you shut it down it will not restart. If you crank it a bit, won't start. If you turn the key on and off 3 times you start to smell Gas, can find no leak. Let the truck set for a while, it starts right up.
Long version:
I got the from the original owner, a mechanic. It has 190,000 on it. Compression in 1, 2, & 4=195, 3=175. It sat for a year before I got it. Pulled passenger plugs, squirted wd40 and into the cylinders, rotated it by hand a few times, let it set over 2 days, drained most of the old gas out and put in 5 gal of new. Squirted more oil in. Did the compression test with old drivers side plugs in with all wires off. Saw good gas squirting on open cylinders. changed all plugs and wires. Changed all fluids. Changed but not filter. Started it up ran fine. Let it run 5 min. shut it down. next day ran it for about 20 min, no problem. Took it for a drive following day, ran like a champ.
Yesterday took it to the dump with a load of trash, check lite came on and the tach just cut out! Check engine lite went out, tach came back on! Check engine lite came on, tach dropped to 0 again but the stayed on this time. still seemed to run fine. Got to the dump, shut it off, couldn't get it started. It felt as if it was wanting to but just couldn't, similar to a carbed vechile that just needs a little gentle goose on the gas pedal. After about half an hour, just before the dump closed and before AAA got to us, I tried it and it fired right up! Got back home (light on tach off), shut it off and tried to start it back up... No luck. Next morning, fired right up.
Thanks for any help
A.J.
Reply With Quote Multi-Quote This Message Quick reply to this message
#2 Add to freirefishing's Reputation Report Post
Old 05-22-2007, 09:43 AM
freirefishing's Avatar
freirefishing freirefishing is offline
freirefishing has a great reputation on FTE.freirefishing has a great reputation on FTE.freirefishing has a great reputation on FTE.freirefishing has a great reputation on FTE.freirefishing has a great reputation on FTE.freirefishing has a great reputation on FTE.
if it died at the dump i would have left it. j/k
code 28=Vane Air Temperature (VAT) sensor out of range - VAT
dont know what the heck that is, good luck
#3 Add to freirefishing's Reputation Report Post
Old 05-22-2007, 09:47 AM
2.3L w/Electronic Ignition - Cyl ID, IDM low or right coil pack failure - Ignition Systems
#4 Add to dazzleaj's Reputation Report Post
Old 05-22-2007, 02:32 PM
dazzleaj dazzleaj is offline
dazzleaj is starting off with a positive reputation.
Thumbs up thanks
Checked the wires to the plug of the coil pack. They were twisted and folded against each other. Straightened them and pushed them a little deeper into the back of the clip and it smoothed out a bit and the check engine lite went out, the tach came back on and it starts after shutting it off!!
I will pull the plug and rebuild it or replace it
Thanks
A.J.
#5 Add to freirefishing's Reputation Report Post
Old 05-22-2007, 03:50 PM
HOLY SH** I ACTUALLY CONTRIBUTED TO POSSIBLY HELPING SOMEONE FIX THERE RIDE!!!!YAAAAAAAAAAAAAAA
all seriousness i hope it works for you, theres alot of people on here that can help out with just about anything for cars and trucks.
good luck
paul
Old Dec 20, 2014 | 05:29 PM
moneypit79's Avatar
moneypit79
I have checked and cleaned all connections to everything including the computer.I guess the computer will be next
Old Dec 23, 2014 | 03:17 PM
moneypit79's Avatar
moneypit79
It was the crank sensor going bad.truck runs great and the tach works again
OneLostCowboy
Apr 7, 2017 12:01 AM
tewferford
1978 - 1996 Big Bronco
Nov 15, 2007 10:33 AM
dazzleaj
Jun 12, 2007 08:19 PM
dazzleaj
May 22, 2007 05:50 PM
Dranger
Feb 15, 2007 10:13 PM
