1978 - 1996 Big Bronco
bucking and lost tach.
Old Nov 10, 2007 | 04:21 PM
tewferford's Avatar
tewferford
I have a 93 Bronco V8. I got in and it started with no problem. Then I noticed the tach was not working. No biggie. After I backed out and dumped it in drive, It started bucking and will not go over 10 mph. Anybody have any idea what happened? TIA guys
Old Nov 10, 2007 | 04:32 PM
khadma's Avatar
khadma
Carpenter Local 745
My FSB was running rough after not driving it for a couple of months. I think I had bad gas. Put new gas and use Lucas injector cleaner in the tank. My truck runs like a top now.
Is your charging/battery system okay?
Gotta start somewhere.
Old Nov 10, 2007 | 04:43 PM
khadma's Avatar
khadma
Carpenter Local 745
Check timing too, I should do mine today too.
I have to get away from this stupid computer first though.
Old Nov 10, 2007 | 04:48 PM
shift1313's Avatar
shift1313
can you give us some more info? like was the truck sitting for a long time. did you recently fix something etc.
sounds like a fuel issue, either tps. a bad sensor or something along those lines.
my 89f150 ran great and one day i came home for lunch, 30mins later on my way back to work and it started bucking and running really bad. It was a combo of things but i ended up replacing the ignition coil as well as all the plug, wires, cap/rotor and all was fine again.
Old Nov 10, 2007 | 04:51 PM
khadma's Avatar
khadma
Carpenter Local 745
I forgot - I too changed my 130,000 plus cap and rotor. TOTALLY SHOT.
good catch -shift1313.
Funny it was only a week ago and I forgot.
Rough week at work for me.
Old Nov 10, 2007 | 05:24 PM
tewferford's Avatar
tewferford
It wasn't even 30 mins. I'm swaying towards the coil or at the very least the wiring to it. Why would the tach stop working all of a sudden? It is wired into the coil. correct?
Old Nov 11, 2007 | 08:40 AM
lostin90s's Avatar
lostin90s
Yes the tach is wire into coil. He could check it it has 130000= As said (they usually go longer than that). But I swap em out on every new to me truck I get .
Old Nov 11, 2007 | 10:30 AM
shift1313's Avatar
shift1313
coils are cheap to replace if you think its a problem.
your tach could also go out if the power or ground to it goes bad. if you have a stock in dash tach thats not usually the case.
the weird thing is you said it started and ran fine when you noticed the tach wasnt working. And the bucking didnt start til you went forward.
Is everything fine if you drive in reverse? what about free revving in N.
Old Nov 12, 2007 | 05:35 AM
tewferford's Avatar
tewferford
It will rev up with no load, when you put it in any gear to drive, it starts to buck. And yes it is a stock in dash tach.
I have not had any time to look at it b/c I am racing against mother nature to get my roof closed up.
Old Nov 15, 2007 | 04:38 AM
tewferford's Avatar
tewferford
I found it!!!!!!! I blew the fuse to the alt. All is well again in Bronco world.
Old Nov 15, 2007 | 10:33 AM
khadma's Avatar
khadma
Carpenter Local 745
right on tewfer, something for all of us to remember to check.
thanks
