Battery drain
Old Dec 18, 2014 | 05:51 PM
joelewis73's Avatar
joelewis73
Battery drain
I did the EGR, delete, and oil,cooler yesterday and truck was running pretty rough to start off with. Hard start lots of turning over to start..now as soon as I turn the key to on interior lights dim and battery runs down really fast..will not even turn over at all...got the charger on it but not to confident it's going to work.
Thanks
Joe
Old Dec 18, 2014 | 06:56 PM
cheezit's Avatar
cheezit
Test the batteries.
Old Dec 18, 2014 | 08:54 PM
Jmoen7's Avatar
Jmoen7
Thanks
Joe
Get them tested and get new ones if you need, don't hold onto bad batteries it will hurt your other electronics in the long run. Like your FICM.
Get the biggest CCA batteries with good warranty you can find.
Old Dec 18, 2014 | 09:52 PM
joelewis73's Avatar
joelewis73
I just put new ones in less than 3 months ago....it charged and is running but it's pulsing and the hood light is pulsing what would cause this...I'm thinking a wife got picked when I was working under the hood and could be shorting? Ideas?
I will also grab a couple new red tops from work in the am and swap them out to see if it helps any.
Old Dec 18, 2014 | 10:18 PM
joelewis73's Avatar
joelewis73
It's running and actually running good...have the following codes
P2065--injector circ high cylinder 2
P2066-- cylinder 2 contribution balance fault
P2068--injector circ high injector 3
P603-- internal KAM error--- happen every time I change tunes in the truck
P2269-- water in fuel condition? I drained like a quart of fuel last night and is coming back change filters?
P2065, p2068, are new codes popping and now my abs light is on? I am supposed to take a trip this week tomorrow more exact but truck is bugging me..running smoother right now but hope it's not calm before the storm..I kmow inj2 needs to be changed have two on order just not here yet...thanks
Joe
Old Dec 18, 2014 | 10:28 PM
dlibson's Avatar
dlibson
Looks like two injectors, based on codes. Check the water in fuel sensor, it could be bad.
Old Dec 18, 2014 | 10:53 PM
joelewis73's Avatar
joelewis73
That is inside where the full pump is right?
I got two injectors coming and they are on my list of things left to do...#3 is new two is same as before..used to have codes fr 2 and eight but I tried that sea foam thing before I swapped the cooler out and 8 is gone..
Thinking I will go back over the connectors on the injectors when we pulled the manifold to make sure the are all tight and seated...1-7 drivers side 2-8 passenger right?
Then on a lighter note...replaced the 4wd module and the transfers case motor and slips in and out of 4wd with ease and new manual lockers so she is definately getting there
Thanks
Joe
Old Dec 18, 2014 | 10:56 PM
dlibson's Avatar
dlibson
Yes, you are correct on the locations, Also check the FICM and connectors.
Good to hear on the 4WD!
Old Dec 19, 2014 | 12:14 AM
LWW's Avatar
LWW
Check your alternator too. Mine was only generating 11.5v at cruise and was causing havoc with other electronics. Went through 2 sets of batteries and a FICM before I wised up and put a cheap voltage gauge into the CLA and realized what was up.
Old Dec 19, 2014 | 07:49 AM
joelewis73's Avatar
joelewis73
I checked the alt and is putting out 15v so that is good...i checked the connections and the back plug was not all the way in. Doing good right now drive to work just the buck and jump as before when shifting in last gear. That is the injector issue i think..new ficm last may along with programming... all i can say is i love my truck...
Old Dec 19, 2014 | 07:53 AM
npccpartsman's Avatar
npccpartsman
Thanks
Joe
Reverse what's in RED. 1,3,5,7 are on passenger side.
Old Dec 19, 2014 | 08:05 AM
joelewis73's Avatar
joelewis73
Ok thank you thats why i asked...lol
Old Dec 19, 2014 | 08:38 AM
dlibson's Avatar
dlibson
Good catch Tim, I missed that question.
Old Dec 19, 2014 | 10:13 AM
joelewis73's Avatar
joelewis73
Like i said calm before the storm...hemoraging oil From the top.
Oil cooler gasket or turbo oil tube?
Old Dec 19, 2014 | 04:28 PM
npccpartsman
That's hard to know but fairly easy to find by climbing on top of the motor. IMHO it's easier to find in the dark with a flashlight so you can see the stream.
The WIF code could be from a corroded sensor. Fairly common issue.
The injector codes "MIGHT" be FICM. Check the middle plug for a good connection as 2,3,5,8 cylinders are "fired" from that plug.
