Sponsored by: Real Truck
Steering wheel noise
Old Dec 18, 2014 | 02:47 PM
lowrider57's Avatar
lowrider57
I have a 2002 Ford F250 and recently had new ball joints,hub and bearings and locking hubs put on and now I have noticed when turning the steering wheel sounds like something in the steering wheel is rubbing. Every time I turn left or right it makes this noise,it's not real real loud but it is audible. Any ideas? Did have one guy tell be squirt WD-40 into the steering column.
Old Dec 18, 2014 | 04:34 PM
dmallen's Avatar
dmallen
If you're talking about a noise that sounds like rubber rubbing on metal...sort of a squeak, but with a lower pitch than you would think, then I have the same thing in my '06 F250. I've been thinking about dismantling the steering column and applying some lithium, but then I think about how much work that would be and then I think it's really no big deal.
Old Dec 18, 2014 | 05:21 PM
Magnus E's Avatar
Magnus E
I have the same thing in my 05 Ex - eagerly looking for a good tip on how to rectify...
Old Dec 19, 2014 | 10:02 AM
lowrider57's Avatar
lowrider57
steering noise
Thank you I guess I will do as you say just leave it alone. If anyone else has a say please post.
Old Dec 19, 2014 | 01:42 PM
Mcrafty1's Avatar
Mcrafty1
If it's the rubber on metal squeak check the steering column where it passes through the firewall and while you're there spray a little silicone lube on it and see if it helps. I seriously doubt if it's inside of the column itself where the noise is being generated.......jmho
MCG DAWG
May 31, 2017 08:52 PM
biker55
1997 - 2003 F150
Jan 24, 2015 12:56 PM
Gangley
Sep 26, 2013 08:42 AM
jbdecke1
Sep 11, 2006 12:47 PM
euch
Bronco II
Dec 23, 2005 02:28 PM
