NO 4X4!!
Old Dec 17, 2014 | 04:54 PM
99F350bigorange's Avatar
99F350bigorange
Not sure if the wires were for the tcase or the tranny. I just cut em spliced em with some butt connectors and heat shrink taped them up and checked all the fuses under the dash and the hood. Then I rechecked for power to that connector and nothing. Next step all I can think to do is find the connector for the GEM and back probe it and see if power is coming in and then see if it comes back out to the 4wd. Just not sure which pins to back probe to figure that out. Any ideas?
Old Dec 17, 2014 | 04:59 PM
David7.3's Avatar
David7.3
Did you try to reset the GEM? disconnect the batteries for 15 minutes, those wires could have tripped a code and is locking the 4x4 out, scan tool would be better but batteries will work too, just screws the radio and stuff up.
Old Dec 17, 2014 | 05:15 PM
99F350bigorange
I will give that a try as soon as I get home tonight.
Old Dec 17, 2014 | 05:20 PM
David7.3's Avatar
David7.3
I think you might get lucky!!!!
Old Dec 17, 2014 | 05:28 PM
99F350bigorange
That would be awesome if it worked! Like you said I might get lucky! Haha
Old Dec 17, 2014 | 05:51 PM
DieselDenny's Avatar
DieselDenny
Before you throw it all in.
Your done for the evening I take it.
Pull both positive cables and reboot in the morning.
I've pulled a lot of leads in my truck, only to find out that (well I couldn't put my finger on it) to put the truck back to default, and vroooo m.
Not something to sleep on, I know!!! GL
Denny
Old Dec 17, 2014 | 06:19 PM
99F350bigorange
I have the negative battery cables pulled off right now. Shouldn't matter negative or positive should it? Should I leave it all night or just like 20-30 minutes good?
Old Dec 17, 2014 | 06:28 PM
Pitcrw6's Avatar
Pitcrw6
Here is a diagram of the ESOF system. Its for a 99 but it should be the same for a 2000. Also do a search on here for ESOF and you will get a bunch of threads. I know Robin (Payson PSD) (Rest in Peace Brother) was a wizard at figuring out 4x4 problems and has tons of info on here for you to read through. Did you check the relays in the eng bay? Those were prone to going bad. I use to have on how to test the relays but cant seem to find it now. Maybe someone can help me out and post it if they have it.
File Type: pdf
Old Dec 17, 2014 | 06:34 PM
99F350bigorange
I will definitely check that out. The relays seemed to be fine. At least I swapped them with some good ones didn't make any change unfortunately . Thanks!
Old Dec 18, 2014 | 09:03 AM
99F350bigorange
Battery cables unhooked all night unfortunately did not help.
Old Dec 18, 2014 | 02:49 PM
DieselDenny
Bigorange, do you have power to the switch itself?
If so, use a jumper after you pull the switch with koeo and see if you hear movement.
If you have power to the switch...........trace down from there. I know you stated that there were broken wires that you mended on the TC. Same coded loom from the switch should go to where you did your repairs.
Power to the switch good. Leave it in 4 hi or lo and get down there and check for voltage. No voltage beyond the switch.
Switcherroo. Pop yours out and borrow one for testing. (Good friends drive superdutys right?)
Denny
Old Jan 9, 2015 | 10:10 AM
99F350bigorange
Well we got a new GEM put in and flashed by the dealership. Got it back and still does not work. Only change I noticed is now I can get 6 volts to the switch. The switch itself ohms out properly in all settings. The two wires that go from the relays to the shift motor have continuity telling me they are not broken. Hooked some power to the relays they click on and off just fine they work. I get power to pin 85 on both relays. However, key on engine off and engine on when I unplug the two wire connector that comes from the relays to the shift motor, the same one that has good wires, no power when switching between all the settings on the 4wd switch. The 4wd lights on the dash still only come on while cranking the engine. I am lost from here. Any ideas? Only thing I can think I haven't tested was checking for breaks in the big connector that has like 6 wires or so on the tcase. I fixed the breaks in the wire I could find. Thanks everyone!
Old Jan 9, 2015 | 05:38 PM
  #28
DieselDenny
Big O
Go for the TC connection and see if you have voltage as you have an assistant Koeo in Neutral roll thru the selector and see what we see.
Don't give up, your close.
Denny
Old Jan 9, 2015 | 05:53 PM
  #29
99F350bigorange
Will try that next. Post my findings later tonight. Thanks!
Old Jan 10, 2015 | 11:14 AM
  #30
Tugly's Avatar
Tugly
Slowing down a bit here. I haven't read any basics yet - this could be a simple vacuum leak (normal) and a burned out dash light.
  1. Do you hear the vacuum start up when you turn the key?
  2. Does the vacuum shut off after a few seconds?
  3. Can you get heat in the cab to your feet?
  4. Have you checked the list of fuses in the PDF Pitcrw6 attached?
  5. If you grab the front drive line, is it locked?
  6. Have you jacked up the front wheels to see if they are locked to the axle?
  7. With both front wheels up and spinning the wheels and front drive line, what is locked and unlocked?
