Help finding new oil pan
Old Dec 14, 2014 | 10:46 PM
Dan Biehl's Avatar
Dan Biehl
Hi everyone,
I have a 1979 F150 300 Inline 6 (4.9L) 4x4 with a 4 speed manual. I have a fist size dent near the oil pan plug. When the previous owner did this it broke the seal of the gasket. I decided to fix this (oil leak) with out paying attention to part matching or numbers, before I ordered a Dorman oil pan for I think a V8 so it doesn't fit.
The numbers I took from the original equipment is D6UE-6675-AA. The D6UE might not be right. What I am trying to find with no luck is a new oil pan that fits this engine. The original oil pan has a port on the driver side for the dipstick, holds 6 quarts and the oil plug is in the rear bottom of the pan.
Where can I find a new oil pan?
Could I used the old oil pan with a new gasket?
A Mechanic told me it's better to replace the pan and gasket if the original had a dent in it. The old gasket did look like it had been flattened out.
I'd provide a picture but I don't have a garage and the oil pan is back on to protect everything from the weather in SD.
Thanks!
Old Dec 15, 2014 | 12:07 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
ID engineering number D6UE-6675-AA - oil pan would not have been on your 1979 F150 4WD originally.
The Ford part number for this pan is: D5TZ-6675-A = 300 I-6 1975/79 Econoline & 1978 F150/250 4WD from serial number AJ0,001 to before serial number BJ0,001.
C7TZ-6675-D .. 240/300 I-6 Oil Pan / Obsolete
1967/72 F100/250 4WD / 1969/72 Econoline / 1973 Econoline before serial number R00,001 / 1973/77 F100/250 4WD / 1978 F150/250 4WD from serial number BJ0,001 / 1979 F150/250 4WD
No Ford dealer or obsolete parts vendor has any.
Old Dec 17, 2014 | 12:15 AM
fordman75's Avatar
fordman75
Check RockAuto Parts Catalog
They should have one.
Old Dec 17, 2014 | 10:24 AM
jack orchard's Avatar
jack orchard
Don't Know if This will Help
You might consider:
Remove dent as much as possible. Make sure pan is is in good general shape to fit to block surfaces. If plug hole is damaged, weld or braze a 1/2" fine threaded nut to bottom of pan. Use a 1/2" fine threaded bolt to use as a new plug. Use a nylon washer for new plug gasket. A new coat of paint and you are good to go. It might not look like new, but it will work and the new plug will never strip out. Total expense - about $2.
This also works to fix a stripped out pan plug.
Like i said, this may or may not help you. Good luck,...jack
Old Dec 17, 2014 | 03:32 PM
lostonmonday's Avatar
lostonmonday
If by weather in SD, you mean South Dakota, and you're in Rapid city, I have a dorman pan that you could have. Its for a 2 wheel drive, so I don't know of it'll work.
Maria E.
Jul 10, 2018 11:06 AM
1965GTFB
Jun 20, 2018 10:49 AM
F'n ford
Jan 24, 2018 04:58 PM
Dorsai
Mar 12, 2013 10:48 PM
imlowr2
Dec 19, 2004 11:18 PM
