Oil pan 84 4wd - Ford Truck Enthusiasts Forums
Oil pan 84 4wd
Old 01-07-2018, 12:09 PM
F'n ford
F'n ford is offline
F'n ford is starting off with a positive reputation.
Oil pan 84 4wd
Hello. This is my first post here. I like the site a lot, lots of good information.
I've looked for an answer but I can' really find a clear answer. I have a 1984 4wd f150. That I'm installing a replacement 300 in it. The replacemnt motor came from a 76 2wd f100 it has a mid sump pan on it. Will the mid sump pan work on the 4wd. I know a front sump won't but will a mid sump work?
Old 01-07-2018, 06:43 PM
Brian_153624
Brian_153624 is offline
Brian_153624 is starting off with a positive reputation.
When I switched mine I just changed the pan and oil pickup. Just make sure you will be able to check your oil. You won't be able to use your original dipstick.
Old 01-08-2018, 10:32 AM
AbandonedBronco's Avatar
AbandonedBronco
AbandonedBronco is offline
AbandonedBronco is a name known to allAbandonedBronco is a name known to allAbandonedBronco is a name known to allAbandonedBronco is a name known to allAbandonedBronco is a name known to allAbandonedBronco is a name known to all
Hi F'n Ford, and welcome to the forums. Yes, lots and lots of good info here. Most everything anyone can think of to do has been done before, and discussed.
With the pan, no, you'll need a rear sump pan for your 300 to fit into the '84. The 4wd TTB front axle takes up a bit of room and the rear sump pan barely clears it as is, so a mid sump will hit the axle.
Dorman makes a replacement oil pan which works really well. I've used two of them. However, on both of them, I had to lengthen the bolt holes on the front of the pan since they're about a 1/4 of an inch off. Otherwise, great fit.
Just note that they don't have the raised ridges around the bolt holes, so you'll need the blue silicone gasket from an '89+ 300, which is a vastly better gasket anyway so... win win.
Old 01-08-2018, 05:28 PM
F'n ford
F'n ford is offline
Thanks for the replies. I have my oil pan and rear sump from my motor I'm pulling but I won't have a dipstick. The engine in mine is an efi block. So my oil pan doesn' have a dipstick. So I guess I'll being going to the local pull a part to find one. Thanks guys!
Old 01-10-2018, 09:29 AM
F'n ford
F'n ford is offline
I found the proper oil pan. Does anyone know where I can find a dipstick for a 1980 oil pan. Has to be the kind mounted on the oil pan
Old 01-10-2018, 10:13 AM
AbandonedBronco
The dipstick itself I believe you can still buy new. However, the tube that threads into the oil pan is a different story. Junk yard or ebay maybe.
Did you find your oil pan in the junk yard and it didn't have a dipstick tube attached?
Old 01-24-2018, 04:58 PM
F'n ford
F'n ford is offline
Someone already got the dipstick off of it
tluns
01-06-2018 12:58 PM
Kyle Wood
04-18-2017 06:33 PM
mike potts
09-06-2016 12:29 PM
TerrySh
1978 - 1996 Big Bronco
08-22-2016 11:14 AM
hasteranger
04-29-2016 03:28 PM
Quick Reply: Oil pan 84 4wd
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
