instrument panel differences
Old Jul 19, 2003 | 01:43 AM
arnolan's Avatar
arnolan
What are the differences between the 67-72 instrument panel gauges and our gauges?
I have seen a few pictures, but I have been unable to get a look at them directly and in person.
I was just wondering how hard it would be to convert 67-72 over to our trucks...specifically mine (66).
Thanks.
Bob
Old Jul 22, 2003 | 11:52 PM
FordBoypete's Avatar
FordBoypete
They're closer to 73 - 79 style, unless you get them from a F600, in which case they are easily adaptable & should work if you get senders with the righr values & parameters for what ever F600 guages you happen to have. Forget the Air Pressure gauge, you can't use it anyway.
I have used Econoline Guages in a "one off" cluster face which I fabricated. They worked good.
But this time I am shortening a 79 Air Dash to fit my 65 F100 cab, so I have indash A/C registers, and controls. I can also hook up a 79 tilt column better with 79 dash. Also better tunes mounting, bigger glove box, better configuration & Pad arrangement too.
It's a lot of work, but it will be removeable when I am done, just like it was in the 79 F150 Ranger XLT I got it out of. . . .FBp
havi
Aug 19, 2010 04:35 PM
Hakk
Oct 25, 2007 10:01 PM
wintremute
Apr 15, 2006 12:06 AM
Nick D
Oct 30, 2005 06:14 AM
gar
Dec 16, 2002 11:49 AM
