99 f350 leveling kit
Old Dec 13, 2014 | 12:07 AM
fordguy2236's Avatar
fordguy2236
Im looking for a leveling kit for my late 99 f350. I know f350's are 1 tons with a solid front axle so it is just a block and longer bolts but im having a hard time finding a kit. they shouldn't cost to much since its just the block and bolts. anyone know of a kit that will work?
Old Dec 13, 2014 | 07:29 AM
Walleye Hunter's Avatar
Walleye Hunter
I didn't think you were allowed to place blocks on the front end and that you need to raise it with springs.
Old Dec 13, 2014 | 09:05 AM
ashleyroachclip's Avatar
ashleyroachclip
Mine is also a 99 and is raised with springs.
Mine is a rough country lift I believe, was on the truck when I bought it .
Old Dec 13, 2014 | 09:27 AM
cclgeo's Avatar
cclgeo
Icon has a 3.5" leveling kit that I used in the past and am probably going to use on my 2000 dually. Its a hanger kit, really liked it before and kept the same ride quality. They also have mini spring setups, but I think that might stiffen the spring pack.
Old Dec 13, 2014 | 10:58 AM
fordguy2236
http://m.ebay.com/itm/181435882953?nav=SEARCH.
Would this work? I just want to do a block style leveling kit. Any ones that you guys would suggest?
Old Dec 13, 2014 | 11:13 AM
HD Rider's Avatar
HD Rider
This is what I have.
F350 2001-2007 Ford 1.5" Front Lift Shackles | Jack-It, The Suspension Experts
Old Dec 13, 2014 | 11:17 AM
SARDiverDan's Avatar
SARDiverDan
DO NOT block the front. You can add a leaf or shackle kit and that will get you what you need but you never add blocks to the front.
Old Dec 13, 2014 | 12:18 PM
fordguy2236
Ok I thought you could block the front. So with the shackles you just replace them and that's all you need to do? I would like at least a 2 inch leveling kit.
Old Dec 13, 2014 | 12:46 PM
HD Rider's Avatar
HD Rider
That's all I had to do. It did not affect pinion angle or alignment enough to require any more work.
Old Dec 13, 2014 | 12:51 PM
SARDiverDan
There are several on the market so it all depends on what type of budget you are looking at in regards to how complicated you want to make it. Some kits have limited parts and its just a quick swap, others (more expensive) are a little more involved and require some extra work. You may need to also look at shocks as well as you are going up another 2" or so.
Old Dec 13, 2014 | 05:39 PM
rcgtsport's Avatar
rcgtsport
i got mine on ebay he has all kinds of sizes i went 1 1/2 shackle. think i pais under 50 bucks. forgot the seller sure he's still there.
Old Dec 14, 2014 | 10:18 AM
HH60FE's Avatar
HH60FE
I did the Sanderson leveling mini spring kit off ebay. I did it in 08 and havent had any issues. The mini spring go under your current springs so the shocks arent affected and the steering wasnt altered. It was a pain to do this by myself, as the main springs moved as soon as the centering pin came free from the hole. I used every cago strap and bottle jack I had to get things lined back up, but I'm happy.
Old Dec 14, 2014 | 07:29 PM
JohnTSMoran's Avatar
JohnTSMoran
F350 Lifted, want to 5th wheel
Gents,
I've got an F350 that's lifted 4" and I'd like to haul a 5th wheel RV. All the discussion above about leveling makes me question if I'll need any special kits before successful 5th wheeling.
Thanks! John
Old Dec 14, 2014 | 10:35 PM
HD Rider's Avatar
HD Rider
Originally Posted by JohnTSMoran
Gents,
Thanks! John
You might have to flip the axles on your trailer.
dyllonmclouth
Mar 10, 2016 11:43 PM
crapr6
Dec 31, 2011 07:50 PM
Powerstroker_18
Feb 21, 2011 12:17 PM
1950gmcelc
May 5, 2009 09:09 PM
wolfbike1500
Dec 29, 2005 02:25 PM
