Need assistance please
Old Dec 11, 2014 | 05:10 PM
Countryboy90's Avatar
Countryboy90
I have a 1986 f150 4x4 5.0l 2bbl carburetor. I just got a new battery, new alernator, new vbelts, and now my battery is running at 11.99v and does not have enough amps to start my truck without jumping it. My alternator is charging my battery. There is no parasitic drain when parked. Just today my tach is stuck on max rpm(6000) and will not move even with battery cables Removed from battery. Please assist me in what I can try next to figure out why my battery and tach are in the state they are in! Thank you
Old Dec 11, 2014 | 05:37 PM
silar's Avatar
silar
Wouldn't the volts be above 13vdc if the alternator is charging the battery correctly?
Is only the tach showing 6000 rpms or is the engine also running at high rpms?
Old Dec 11, 2014 | 05:40 PM
Tedster9's Avatar
Tedster9
11.99 is "dead" for practical purposes. The resting voltage for a fully charged maintenance battery is 12.65 volts, a few tenths of a volt matter a great deal with an auto start battery.
To fully charge a battery requires about 2 volts above the resting voltage - so you want to see over 14 volts with the engine running at a fast idle, or more depending on temperature.
Get the battery on an outboard charger till you get things straightened out. Here are the checks to perform:
http://www.aa1car.com/library/charging_checks.htm
Old Dec 11, 2014 | 06:10 PM
f100beatertruck's Avatar
f100beatertruck
What's the voltage running? If it's not 13.9-14.5v you may have a bad alternator. Are both plugs plugged in to the alternator? Is your alternator internally or externally regulated. Internal will have two plugs, external will have a plug and a screw lug. If it's external, how's your regulator?
Old Dec 11, 2014 | 06:15 PM
Countryboy90
I just got the alternator today and it's integral regulation and the tach is running 6000 with the engine off
Old Dec 11, 2014 | 07:26 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You have a 2G alternator.
Did you replace the charging plug of the harness, as detailed in the Ford TSB?
Every time the charging system is serviced this pigtail needs to be changed because they become corroded and melt internally.
Sometimes they even catch the harness on fire.
Old Dec 11, 2014 | 08:52 PM
Countryboy90
I totally forgot about that. Is it possible that is my problem?
Old Dec 11, 2014 | 09:28 PM
ctubutis's Avatar
ctubutis
The connections *to* the alternator could very well be your problem, do as Jim suggests and at least look into that.
The tach is almost a different, unrelated problem.
What is the voltage at the battery with the engine running?
Old Dec 12, 2014 | 04:46 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Tach is pinned and remains so with the battery disconnected???
I think it is just a bad gauge.
2bbl carb on an '86 5.0 F150?
I was under the impression that 1985 was the transition year and only 4bbl 351 HO and 7.5l trucks over #8,500 were carbureted in '86 &'87
Has someone done a swap and mucked about with your wiring?
Old Dec 12, 2014 | 06:28 AM
Franklin2's Avatar
Franklin2
That's my vote as to what is wrong.
annaleigh
16
Jan 1, 2017 04:01 PM
The_mayor
Feb 19, 2015 01:08 PM
crestfallinman
33
Mar 1, 2012 09:54 AM
Thudpucker
1997 - 2003 F150
19
Jan 15, 2006 06:35 PM
bcsbadboys
Oct 16, 2002 08:04 AM
