battery or alternator shot?
Old Oct 11, 2002 | 11:36 AM
bcsbadboys's Avatar
bcsbadboys
Noticed after driving yesterday that the battery guage on the dash was near the left side and staying there. It isn't charging up as I drive and it was getting very difficult to start towards the end of the day. Drives fine, but starting is tough. Is the alternator not charging the battery or is the battery dying and not allowing itself to be charged?
Old Oct 11, 2002 | 11:56 AM
tw's Avatar
tw
Check to see what the voltage across the battery posts is before you start the engine. Then measure with it running.
If it is below 12 when running it is either the voltage regulator or alternator. If it is about13-14, check the battery connections and cables and try again.
If your battery is several years old and all connections are good, the battery is the problem.
If everything checks out, you could have something draining the battery when it is not running.
If you do not have a voltmeter, you can take it to most auto parts stores, they can check alternators and batteries.
Tony Warren
Nebraska
Old Oct 14, 2002 | 09:23 PM
924x2150's Avatar
924x2150
Chances are, the alternator is wacked. I have the same truck and go through alot of alternators. Most places will check your system for free. Battery might cost $75, Alternator installed-$200, Do it youself maybe$130. The alternator is easy to change but beware the old electrical connector that plugs in the alt. you have to replace the 3-wire connector occasionally.
Old Oct 15, 2002 | 11:27 PM
BlueMeanie's Avatar
BlueMeanie
I went nutty crazy this summer trying to figure this same problem out. I took both the alternator and battery in to Shucks to be 'tested.' They were supposedly both fine. So I went accross the street to GI Joes and bought a new alternator and battery for under $200. Problem solved. Everything worked, and still works, like a dream.
Old Oct 16, 2002 | 08:04 AM
Stephens's Avatar
Stephens
dieseldrivr
Jan 25, 2010 10:41 PM
dgalloway
Jan 5, 2005 08:27 PM
elstx
Electrical Systems/Wiring
20
Jan 3, 2004 02:08 PM
dland
Oct 16, 2002 08:23 AM
kochy54
15
Apr 21, 2002 05:31 PM
