door and lights
Old Dec 10, 2014 | 07:38 AM
billrigsby's Avatar
billrigsby
door and lights
I have a 2010 F 150, it's a work truck. Every time I open the door all the parking lights interior lights cargo lights go on like a Christmas tree. Is there a way to program this truck so when you open the door all these lights do not come on.?
Old Dec 10, 2014 | 10:26 AM
MCDavis's Avatar
MCDavis
It's commonly referred to as "dark mode". As far as I know, the dealer is the only option for this reprogramming.
Old Dec 11, 2014 | 05:48 PM
billrigsby's Avatar
billrigsby
Really, well that about figures?
Any ideas what something like that would run, cost wise?
Old Dec 11, 2014 | 07:39 PM
gDMJoe's Avatar
gDMJoe
billrigsby - I have a 2010 F 150, it's a work truck. Every time I open the door all the parking lights interior lights cargo lights go on like a Christmas tree. Is there a way to program this truck so when you open the door all these lights do not come on.?
Excerpted from the 2010 F-150 owner's manual .....
(owner's manual) Don't have one -OR- would like a digital, searchable desktop document?
Owner's Manuals ««« -click-
» Select Your Year [ Choose One ]
» Select Your Make [ Choose One ]
» Select Your Model [ Choose One ]
-click- the pic'
Goth 150
< This space intentionally -blank- >
Old Dec 11, 2014 | 07:48 PM
gDMJoe's Avatar
gDMJoe
MCDavis - It's commonly referred to as "dark mode". As far as I know, the dealer is the only option for this reprogramming.
True for 2011+ F-150s, however, not for 2009-2010.
For 2011+ there is only one way to disable this - flash the control module.
Take your vehicle to a dealership and have them use their IDS (Intergrated Diagnostic System). *If you have 12,000 miles or less on your vehicle it will/should be *free*.
The module configuration parameter that needs to be changed is ...
Body Control Module (BCM)
» Police dark car feature » -enable-
What this gets you ...
  • interior -AND- all exterior (front / rear parking and cargo) lights do not come-on when the door is opened and/or closed. *EXCEPTION: Door key pad will still illuminate[/size].
  • when the fob is used to lock|unlock the doors, the parking lights come-on/turn-off for a VERY brief moment. *The time that the lights illuminate is MUCH, MUCH shorter than "normal". Would describe it as a flash[/size].
  • when using the key fob to lock the doors, the horn will not sound.
As a BTW and FYI ...
Beginning in 2011 the instrument panel dimmer control changed to a rocker switch (from a roller thumbwheel) and with that change the ability to disable the illuminated entry feature was lost.
Prior to 2011 to disable the illuminated entry feature you only needed to rotate the instrument panel dimmer control thumbwheel to the left position, past the detent.
And Yes, I have the " Police dark car feature" -enabled-
Fleet F-150s and Expeditions that are ordered / intended for law enforcement agency use are shipped with the " Police dark car feature" -enabled-
-click- the pic'
Goth 150
Old Dec 11, 2014 | 07:59 PM
billrigsby's Avatar
billrigsby
-click- the pic'
Goth 150
Tried that only turns off the cargo lamp?
Old Dec 12, 2014 | 09:52 AM
gDMJoe's Avatar
gDMJoe
billrigsby - Tried that only turns off the cargo lamp?
Welp ... If you've turned the dimmer control past the detent and it didn't turn-off the interor lights or disable the illuminated entry feature, then you've got a problem ('cause that's what it's suppose to do).
*Worked for my previous 2009 STX.
Old Dec 12, 2014 | 01:40 PM
billrigsby's Avatar
billrigsby
Well it did work for the interior and cargo lamps,
but all the park lamps still come on.
Rustofer
Dec 10, 2019 08:32 PM
4wheelfurry
2015 - 2020 F150
May 16, 2018 01:39 PM
pepito113
2009 - 2014 F150
13
Jan 31, 2014 03:47 PM
Secret Agent 069
Nova Scotia
Apr 28, 2008 10:20 AM
