MPG Down
Old Dec 6, 2014 | 02:38 PM
ubereal2's Avatar
ubereal2
MPG Down
First off I have a 2011 F150 4x2 Super Crew, 5.0, and have had the truck for almost 18 months and have always gotten at least 16.5 MPG with a mix of city and hiway driving.
Now I'm only getting 14.8, and that's after a nice hiway run a couple of day's ago. Nothing has changed other than Gas Prices have fallen. And I'm really wondering that with the lowering of gas prices, is our fuel being played with?
Unk Bob
Old Dec 6, 2014 | 02:41 PM
NASSTY's Avatar
NASSTY
My fuel mileage gets worse around this time every year because of winter blend fuel and cold weather.
Old Dec 6, 2014 | 02:50 PM
ubereal2's Avatar
ubereal2
Maybe that's something to do with it. I really don't remember my mileage being this lower last winter.
Unk Bob
Old Dec 9, 2014 | 03:52 PM
xr7gt390's Avatar
xr7gt390
It's normal for the mileage to drop with winter blend fuels. I read on a EPA web site once the winter blend fuel have about 1.7% less energy/gallon than summer blends so i guess it stands to reason your mileage will be about 1.7% lower. Here in the mid-west I tend to see more than a 2% drop in winter. Partly because of fuel and partly because of more idling.
Old Dec 9, 2014 | 08:58 PM
CavsQB15's Avatar
CavsQB15
Ditto to what most have said. If you're like me you're taking and extra few minutes to let it warm up and then also it's having to work a bit harder in the cold. I was in the 18-18.5 range up until last week or so when temps stayed consistently cold. Now I'm back down to 17-17.5 on my last tank. It's natural. Nothing to fret over unless it continues into Spring/Summer.
Old Dec 10, 2014 | 09:52 AM
SabreFX4's Avatar
SabreFX4
I ALWAYS see a 1 - 1.5 mpg drop through the winter months. It's a combination of the winter fuel and the engine sensing the cooler, denser air and adding more fuel to the mix.
Old Dec 10, 2014 | 10:04 AM
gDMJoe's Avatar
gDMJoe
IT'S WINTER ...
  • longer warm-up. *Time it takes for the engine to get-up to operating temp'.
  • lower PSI in the tires. *You did adjust them for the cooler temp's, right?
  • more rolling resistance until the driveline gets-up to operating temp'.
  • seasonal blended fuel. *Which Raleigh/Durham is notorious for.
    etc., etc., etc..
-click- the pic'
Goth 150
< This space intentionally -blank- >
Old Dec 11, 2014 | 09:10 AM
ubereal2's Avatar
ubereal2
Well the majority have spoken, and have the same answer. I did get me a hiway ride in earlier this week, and seen over 20 mph. That last tank was almost all city driving, and that is sure to nock it down.
Thanks everybody
Old Dec 12, 2014 | 06:53 PM
cajuncarguy's Avatar
cajuncarguy
4wd Low
My 2011 5.0 had a 2 mpg drop staring last spring. I currently have 48,000 miles. I don't drive as hard as I did when I was younger and was driving a lot of city miles. I know that carbon build up caused "octane creep" by 1) slightly reducing the size of the combustion chamber and 2) acting like a glow plug, both causing pre-ignition. To counter this the knock sensor sends a signal to the ECM to retard the timing, which decreased power and increase fuel consumption. I know from experience that doing a induction system/combustion chamber decarbon cleaning service would make it run like new. Since it costs about $150-$200 to do I decided to try something different. I ran 2 tanks of Shell Premium with the hi tech cleaning additives in it (most Tier One fuels will have this, especially the premiums). I also drove it hard for about 2 weeks. I then went back to regular gas and I swear it is running better and the MPG is back up where it was. Now this is probably not as effective as the Induction System Service but worth a try. Good luck.
Old Dec 13, 2014 | 12:08 AM
CavsQB15's Avatar
CavsQB15
I have done the same thing in many vehicles and see results. Usually every 10 or so tanks I run a tank of hi-test through to give it a cleaning (or assumed cleaning) it always seems to perk it up when I run back to lower octane. Good tip.
Mar 19, 2016 02:10 PM
gtosteve65
Dec 26, 2013 09:43 PM
Budman1962
Modular V10 (6.8l)
20
Dec 27, 2007 07:06 PM
tym2clm
Modular V10 (6.8l)
Dec 28, 2005 03:51 PM
DaneCalvin
Dec 19, 2003 09:56 AM
