Engine Knock.....Remove Engine or Go at it from Underneath
I have a loud engine knock in my 51 flathead. It sound like a rod or maybe a wrist pin. It does not go away when I speed up the engine. I took the belts off the engine eliminating the fan, alternator, harmonic balancer and water pumps. The knock is still there. The engine runs good, it just suddenly developed a knock.
I am new to the flatheads and this is my first time to have to work on one. My question is should I pull the engine or attempt to find the problem from underneath by removing the oil pan. I feel like I can probably pull the engine faster than wrestling with the oil pan. Any experts care to chime in on this?
The pan takes less than an hour to pull, just jack the truck up by the frame, put it on jackstands, the front axle now won't be in the way. But what can you really do with it off? To fix it right you need it out, and may as well find out what shape everything else is in.
Agree......it will be much easier to work on the engine if you pull it. My flattie had a minor knock but ran good.......ended up doing a full rebuild. Figured as long as I had it apart, might as well do it right.
Not so fast (yet) I've heard funky knocks all of a sudden from a bad
fibre cam gear. Seeing your fans off 2 minutes to pull the timming cover
off, I know, It happened to me, sounded like something came undone in
the bottom end. Im going thru that as I speak cant get my distrubutor
out so 5 bolts dist/ cover and all easy...
And don't rule out a carbon chunk that broke loose and being hit each time the piston is at TDC. Did you notice any oil pressure drop when the noise started?
Oil pressure is the major clue. If it is that "hard" a knock I'd even wonder if the flywheel/clutch is loose or busted. By all means get it out of there without further running.
I've been thinking about the flywheel area. I just can't pin point the noise yet.
After checking the compression and finding the #7 cylinder dead, I decided to remove the head and what I found was not good news.
It appears the valve seat disintegrated and pieces were being pounded against the head and piston.
Fortunately the cylinder wall appear to be clear from damage.
Now I will be pulling the engine and hope the block can be repaired with a new seat and valve job.
I think you'll be fine, at the worst a new piston and a head (both cheap). Ask Harleymsn about it!
Edit: you could have bent the rod, I guess. Are you planning to yank it now? Usually the cause of a seat popping out is overheating, either locally or overall. Any engine as old as these nearly always benefits from a thorough cleaning of the water jackets, perfect time if you have it out.
That sucks. Take a close look at that cylinder and rod. I had this happen once on an OT engine(piece of hardware down the intake)......bent the rod and cracked the cylinder wall. Not pretty!
