Valve stems on dually
Old Dec 9, 2014 | 04:53 PM
Joe_fummins's Avatar
Joe_fummins
I'm going nuts trying to get the right setup for these stupid wheels! Does anyone have pictures and or part numbers for the valves they used on their dually wheels so you can fill both from the outside and not use the stupid bolt on brackets for them?!?!? Any help is greatly appreciated
Old Dec 9, 2014 | 05:09 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Old Dec 9, 2014 | 07:46 PM
Diesel_Brad's Avatar
Diesel_Brad
You need those "stupid" bolt on brackets.
Old Dec 9, 2014 | 07:57 PM
FORDF250HDXLT
oh yeah,those parts i updated too.instead of using the flimsy types (i had two failures causing flats) and i got these for both trucks;
http://www.ebay.com/itm/TYRE-VALVE-EXTENSION-HOLDER-CLAMP-MOUNTING-BRACKET-TRUCK-VAN-X2-/191293650474?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c89fd762a&vxp=mtr
the extensions snap right in the loop good there and then you have a bolted part rather than just a slide on clip.much better.sucks to support China as always though.
Old Dec 9, 2014 | 11:05 PM
Joe_fummins
Issue
I had the ones the lug nuts hold on but they never stay in the right spot tightening and it pisses me off trying to make them work, how does that other style work and why can't I just use a 135 valve and extension for the inner tire?
Old Dec 9, 2014 | 11:56 PM
Joe_fummins
Sorry
I don't want to sound like a dick, if there's a reason that extension won't wo I'd love to know, this is my first dually and so I'm totally new to this
Old Dec 10, 2014 | 02:35 AM
eagle275's Avatar
eagle275
Not trying to hijack but I'm looking for some good metal valve stems for my 96F350SRW. I don't know what size is used on these 16" steel wheels. I want them long enough to make it easy to put the air in. Brass, stainless, chrome, whatever is best. Inner mount or outer mount,etc. Want a good seal. Need a set of 4. Where can I find these? Will racing valve stems work? Thanks!
Old Dec 10, 2014 | 12:24 PM
Diesel_Brad
Because "extensions" will not line up with the holes in the outer rim. And the bolt on brackets are to bolt on to the AXLE bolts, Not the lug nuts
Old Dec 10, 2014 | 12:25 PM
Diesel_Brad
Here ya go. But any tire shop worth a darn stocks them
10 New Tubeless Tire Valve Stems High Pressure | eBay
snorindad
Dec 31, 2020 09:03 AM
wrvond
Mar 18, 2018 10:15 AM
tuke
May 11, 2007 03:28 PM
